    Triode/Ultralinear mode switch specs?
    JunkyJan
    JunkyJan
    Triode/Ultralinear mode switch specs? Empty Triode/Ultralinear mode switch specs?
    Post by JunkyJan Mon Aug 30, 2010 12:36 am
    Hello Bob and all,
    I have started work on a set of Mark 3 monoblock amps, and I am planning to add a Triode/Ultralinear mode switch to both.
    What should the specs be for the actual toggle switch? I have sourced a DPDT toggle switch from a local electronics store that physically looks identical to the ones supplied in your ST-70 kit and is spec'ed as follows:
    "125 VAC 6 Amp
    250 VAC 3 Amp"
    (and I guess that it should be able to handle 1.5A @ 500 Volts)
    Is that acceptable?
    -- JunkyJan
    BC, Canada
    Triode/Ultralinear mode switch specs? Empty Re: Triode/Ultralinear mode switch specs?
    Post by Bob Latino Mon Aug 30, 2010 7:31 am
    JunkyJan wrote:Hello Bob and all,
    "125 VAC 6 Amp
    250 VAC 3 Amp"
    Is that acceptable?
    -- JunkyJan
    BC, Canada
    Hi Jan,
    That switch will work fine as a triode/pentode switch.
    JunkyJan
    JunkyJan
    Post by JunkyJan Tue Aug 31, 2010 12:55 am
    Bob Latino wrote:That switch will work fine as a triode/pentode switch.
    Thanks a ton for the information, Bob - much appreciated!
    -- 'Jan
    JunkyJan
    JunkyJan
    Post by JunkyJan Thu Sep 09, 2010 1:48 pm
    Hi Bob and all
    More questions: You recommend a 100 Ohm / 1 Watt resistor to be used to "tie the plates together" when running in Triode mode.
    1) Would a Carbon Film resistor (1 watt) work?
    2) I have a whole bunch of 100 Ohm 2 Watt Metal Oxide power resistors, will that work too?
    3) Same spec whether you use it in a ST-70 or a Mark III?
    Thank you for your time & advice :-)
    -- 'Jan in BC, Canada
    Post by Bob Latino Thu Sep 09, 2010 2:08 pm
    JunkyJan wrote:Hi Bob and all
    Hi Jan,
    What you do is disconnect the GREEN or GREEN/WHITE wire at pin #4 of each output tube and insulate the end so that it can't short out to the chassis. You then tie the plate (pin #3) of each output tube through a 100 ohm resistor to the SCREEN (pin # 4).
    1) Yes
    2) Yes
    3) Yes
    Some "Dynaco Dudes" even suggest a 100 ohm 1/2 watt resistor but there is a lot of heat under that chassis and IMHO you are better off with a 1 watt (or higher) resistor to make the triode connection.
    JunkyJan
    JunkyJan
    Triode/Ultralinear mode switch specs? Empty Thanks a ton, Bob!!
    Post by JunkyJan Thu Sep 09, 2010 4:48 pm
    Thanks Bob - very much appreciated! I'll be running it through a switch so that I can still switch back to the ultra-linear tap, same as your ST-70 kit works.
    Again, thanks a ton!
    -- 'Jan
      Current date/time is Fri Apr 19, 2024 12:12 am
