I'm more than a little confused about the wiring schema between the improved VTA I/O back panel strip and the PAS3-Z PC-6 phono board. My version of the PAS3-Z phono board (I understand there are a number of versions) has one 8 pin connector at the end nearest the volume control and a 4 pin connector closest to the back panel. In the photos I received w/ the kit it is clear that the twisted pair wiring for all inputs have the ground soldered at the phono input jack - but not connected at the selector switch. This I understand. However, I am confused by the photos that show shielded cable running from the phono jacks to the 8 pin connector on the phono board. In the photos it APPEARS that at the I/O board end the center conductor and shield are soldered to the center and ground tabs on the L/R jacks and then are attached to the IN1 and IN2 AND also to ground. Am I seeing this correctly? Or, are the shields left disconnected at the phono jack end???
Thanks for the help!
