    PAS4 Preamp
    Re: PAS4 Preamp
    Post by Bob Latino on Tue Mar 22, 2016 10:16 am
    The PAS-4 was very well made. One large PC board with sealed solder traces ... These units still sell for big bucks if you can find one ... See photo below ..
    pmarcin
    Re: PAS4 Preamp
    Post by pmarcin on Thu Mar 24, 2016 5:03 am
    I wasn't that impressed with the linestage. I had built your SP9 and found that unit at least as satisfying.
    Re: PAS4 Preamp
    Post by tubes4hifi on Wed Apr 20, 2016 8:08 pm
    OK guys, come and get them!!   PCBs and parts came in today, here's a photo of the board.
    PCBs shipping out tomorrow.  I've got one left for myself, and one more left for someone lucky who grabs it up quick!
    I should have the board stuffed with parts by Saturday (got to finish another customer preamp tomorrow) and likely
    powered up and tested by middle of next week, so check back here for more photos!
    The left half of the board is the phono stage and line stage, identical to the original, although I'm adding the provision to substitute
    6FQ7 or 12AU7 tubes in the line stage with minor resistor changes. The right half of the board includes two filament regulators,
    one for the phono section, one for the line stage, and SIX individual high voltage regulators, one for each tube (same scheme as the orginal,
    but using newer, better parts). The HV rectification is done using schottky diodes, each with an RC filter across it.
    And finally, in the bottom right, is the original auto mute circuit, using a timer IC and a relay to disconnect the outputs during warmup.
    Right down the middle are 6 large film capacitors for HV bypass (one for each tube), also same as original.
    Re: PAS4 Preamp
    Post by tubes4hifi on Sat Apr 23, 2016 3:10 pm
    OK, so here's the board stuffed with all parts, now just need to power it up and test, check back in a few days . . .
    Re: PAS4 Preamp
    Post by tubes4hifi on Sat May 21, 2016 5:37 pm
    Re: PAS4 Preamp
    Post by Bob Latino on Wed Oct 12, 2016 10:49 am
    Someone requested a PAS-4 schematic .... See below ..
    NOTE - If the whole image does not show up on your screen then right click on the photo and then "Save image as" and you will save the full sized photo on your computer.
    Thx1326
    PAS4 Mods
    Post by Thx1326 on Fri Jan 27, 2017 4:06 pm
    I also replaced the volume and balance controls with Alps Black Beauties - Volume control is stepped.
    New project is to add a loudness circuit and possibly tone controls which can be bypassed completely if needed.
    muncybob
    Re: PAS4 Preamp
    Post by muncybob on Sun Feb 12, 2017 7:56 pm
    They still do pop up from time to time:
    http://www.ebay.com/itm/142276806568?ul_noapp=true
    No affiliation, just sharing the love.
    daveshel
    Re: PAS4 Preamp
    Post by daveshel on Thu Mar 23, 2017 1:13 pm
    I started Roy's PAS-4 clone last year and never finished it. I'm thinking about finishing it now, because I'm not that thrilled with the phone section in my current preamp. I have a PAS Akaido (love the linestage!) with the PH10 at the moment. Those of you who are familiar with these, how would you say they compare?
    Re: PAS4 Preamp
      Current date/time is Mon May 21, 2018 2:59 am
