    Wattage ratings of Mark3 resistors
    Post by garyb on Thu Jan 06, 2011 4:16 am
    Hi, new guy here, I am ordering parts for Mark 3 boards. What are the resistor ratings? Another question, the instructions that came with my boards specify 12AT7 while the Mark 3 order page specify 12AU7 tubes.
    Re: Wattage ratings of Mark3 resistors
    Post by Bob Latino on Thu Jan 06, 2011 6:11 am
    If you mention 12AU7 tubes and 12AT7 tubes then you must mean the VTA Mark III upgraded driver board.
    The standard gain board which uses 12AT7 driver tubes uses all 1/2 watt resistors.
    On the lower gain board which uses 12AU7 or 12BH7 driver tubes most of the resistors are 1/2 watt except ..
    R16 is a 1 watt resistor
    R18 is a 2 watt resistor
    R20 and 22 are 2 watt resistors
    R12 and R14 are 2 watt resistors
      Current date/time is Thu Mar 22, 2018 3:34 pm
