    ST-70 Rectifier Voltage Readings
    Bugs
    ST-70 Rectifier Voltage Readings Empty ST-70 Rectifier Voltage Readings
    Post by Bugs Mon Jan 17, 2011 7:43 pm
    One of my ST-70s developed a bad buzz and just all around poor sound quality compared to my other ST-70.
    I decided to check my voltage readings to see if anything was unusual. The rectifier pin 2 and 8 readings to ground are about 325 V which I understand to be ~ 100 V too low. The voltage readings on pins 4 and 6 to ground are 0.1 mV which I'm assuming this is how my meter reads 0 V.
    The voltages on the quad cap and EL 34s are correspondingly low. For the EL 34s, the readings across pins 2 and 7 is 0.2 mV and pin 3 to ground is 0 V.
    The quad cap readings range from 276 V to 325 V.
    I'm assuming that my power tranformer is toast?? Should I be checking anything else?
    ST-70 Rectifier Voltage Readings Empty Re: ST-70 Rectifier Voltage Readings
    Post by Bob Latino Mon Jan 17, 2011 8:11 pm
    Bugs,
    On pins 4 and 6 check the AC voltage (not DC) to chassis ground. You must have had your scale on DC to measure only .1 volt on pins 4 and 6 of the rectifier socket. You could NOT be getting .10 VAC on pins 4 and 6 and then get 325 DC on the quad cap. You should get about 360 AC from both pins 4 and 6 to chassis ground.
    The most common cause of low B+ DC voltage is either a bad rectifier or a bad quad cap. If you get about 350 to 370 VAC from pins 4 and 6 of the rectifier tube then the power transformer is OK. If get low voltage here then the power transformer is bad.
    Bugs
    Post by Bugs Tue Jan 18, 2011 12:15 am
    Thanks Bob, you were right I was measureing DC. Pins 4 and 6 measure ~383 VAC.
    I switched rectifier tubes and ruled that out as a source of the problem.
    These are the out of spec readings.
    Output tubes:
    Pins 3 and 4 ~ 319 VDC - all tubes.
    Across pins 2 and 7 , no measurable reading - all tubes
    Quad Cap:
    Lug to B+ voltage ~ 284 VDC
    All other lugs ~ 322 VDC
    Does this sound like the problem is the quad cap?
    Post by Bob Latino Tue Jan 18, 2011 6:10 am
    Bugs wrote:Thanks Bob, you were right I was measureing DC. Pins 4 and 6 measure ~383 VAC.
    Output tubes:
    Quad Cap:
    Bugs,
    Across pins 2 and 7 is an AC voltage. You should get 6.0 to 6.5 VAC.
    If you replaced the rectifier tube, about the only thing that could cause the low voltage is a leaking quad cap - replace it ...
    Bugs
    Post by Bugs Wed Jan 19, 2011 5:12 pm
    Thanks Bob.
    There is a reason I don't do this sort of thing for a living. Quad cap is on the way.
    Best
      Current date/time is Thu Mar 28, 2024 9:32 am
