    VTA ST 70 DUAL MONO POWER SUPPLY
    kost
    Post by kost on Fri Feb 18, 2011 10:28 am
    Hi to all
    I wonder what will happen if someone modifies a VTA st 70
    in dual mono external power suply configuration.
    I mean that you have a seperate chassis with two power transformers,two rectifiers,two power filter capacitors.
    Any advise????
    Re: VTA ST 70 DUAL MONO POWER SUPPLY
    Post by Bob Latino on Fri Feb 18, 2011 11:51 am
    Hi Kost,
    What you are describing is basically a pair of Dynaco Mark IV's which are pretty much an ST-70 on two separate chassis. If you want something like this I would look for a pair of Mark IV's on Ebay and then get a pair of VTA driver boards from Roy at tubes4hifi. If you are going to play monoblocks like this on a daily basis you should probably go through both amps completely and replace both quad caps, tube sockets and any other parts that look worn.
      Current date/time is Fri May 25, 2018 8:44 am
