by Pooch on Sat Feb 19, 2011 3:28 pm
Thanks, Bob. I peeled back the wax paper to see if the solder joints were weak, where the B/W, G/W connect to the windings. They seemed OK but I re-flowed them and added a little solder, just to be sure.I hot glued the wires back down and the wax paper on top of the wires. This worked remarkably well, if anyone wants to try the hot glue idea. I'll try and use the transformer, see what happens.Still about 145 ohms on the meter, though, so the connection wasn't at fault.
Here's my tale of woe
I re-did these Mk4s using VTA boards, new PS Multi section CE cap (80uF variety), new wiring, tube socket,jacks,binding posts, power cord. The only re-used stuff is the choke, transformers and chassis. Everything worked fine for a while, then a power transformer went out. I bought new PS transformers and after installing them and bringing the amps up on a variac, I noticed one was having a soft intermittent popping coming out of the speaker I had hooked up. After reading one of your sticky posts, it seems the PS cap may be at fault? So I disconnected the wires to it and measured. The square section (40mfd) was shot(couldn't get a reading, just flashing).I had this bridged over to the triangle (30mfd) section and then wired to the B+.Is this a wrong thing to do? Should I just stick with the 30mfd section, or is this just a bad cap? Come to think of it maybe this cap took out my original PS. Would I be better off to go with a PS board instead of the multi section?
Thanks again,Bob, for all the help you provide on this forum.
