    Power transformer dynaco mark 4
    mirco64
    Power transformer  dynaco mark 4 Empty Power transformer dynaco mark 4
    Post by mirco64 Mon Jun 20, 2011 1:22 pm
    Hello, I have a Dynaco Mark 4, the power transformers getting too warm after 1 hour from power on.the bias voltage is at 1.1 Volt, it is normal ?
    thank you
    hello.
    Power transformer  dynaco mark 4 Empty Re: Power transformer dynaco mark 4
    Post by Bob Latino Mon Jun 20, 2011 2:21 pm
    mirco64 wrote:Hello, I have a Dynaco Mark 4, the power transformers getting too warm after 1 hour from power on.the bias voltage is at 1.1 Volt, it is normal ?
    thank you
    hello.
    We have had other posts about power transformers on Dynaco power amps getting pretty warm after being on for an hour or two. Heat emanating from a power transformer is normal and having hot tubes pretty close does not help things. If the amp plays normally I wouldn't worry about it.
    mirco64
    Post by mirco64 Mon Jun 20, 2011 2:54 pm
    ok. thanks for the answer
    Hello Mirco
      Current date/time is Thu Mar 28, 2024 12:45 pm
