    What is the bias setting the the ST-70 Kit?
    Mike16W
    What is the bias setting the the ST-70 Kit? Empty What is the bias setting the the ST-70 Kit?
    Post by Mike16W Wed Mar 02, 2011 3:08 pm
    I have one the ST-70 kit running the Golden Lions KT-66 tubes. I have misplaced my manual. Bob was good enough to send me the schematic but now I want to check the bias and don't have the figures. Can someone tell me what the bias setting should be when taken from the front tube sockets.
    Mike
    Mike16W
    What is the bias setting the the ST-70 Kit? Empty Re: What is the bias setting the the ST-70 Kit?
    Post by Mike16W Wed Mar 02, 2011 3:19 pm
    And the test points and which pot to adjust. Sorry for all the questions.
    Mike
    Post by Bob Latino Wed Mar 02, 2011 3:58 pm
    EL34's are biased at .40 VDC on the VTA ST-70 amp kit. On the Gold Lion KT66 you can go up to .45 VDC per tube.
    For all VTA ST-70 KITS > The test point for the front tube on each side is the hole on the front tube socket that says "Biaset 1.56V". Measure there and turn the bias pot on the driver board next to the FRONT tube. For biasing the rear tube use the hole opposite that hole and use the rear bias pot to bias the rear tube on each channel.
    If you have a wired and tested amp from me then the rear tube bias measuring point is on a different hole on the front tube socket.
    Mike16W
    Post by Mike16W Wed Mar 02, 2011 4:09 pm
    Thanks Bob for your help.
    Mike
      Current date/time is Fri Apr 26, 2024 11:40 pm
