    Dynaco ST-70 bias problem
    Albert Isaza
    Post by Albert Isaza on Tue Apr 05, 2011 12:55 pm
    Hi Bob
    Thanks for replying to my post.
    I replaced the 10K resistors for 5.1K, then I turned
    the amplifier on and after about 20 minutes later
    I could rebias the output tubes on both channels
    to 1.40 volts.
    Thank you for your help.
    "Best Dynaco Forum"
    albert.
    Re: Dynaco ST-70 bias problem
    Post by Bob Latino on Tue Apr 05, 2011 3:47 pm
    Hi Albert,
    What happened to you when you replaced the selenium rectifier with a diode and found an improper bias range is a common occurance. Because a diode has more "forward voltage" than a selenium rectifier, those two 10K resistors on the 7 lug terminal strip have to be made smaller to get the bias into the proper range. You are also wise to bias the tubes a little lower than Dynaco recommended. Biasing at the "1.56 VDC" that Dynaco recommended back then is now considered a little on the high side. With a stock driver board, a 1.40 to 1.45 VDC bias point will get you more life out of your output tubes and your amp will sound just the same.
      Current date/time is Mon Feb 19, 2018 5:49 am
