    Blown 10 ohm to grnd resistor on El34
    Pooch
    Post by Pooch on Thu Apr 21, 2011 1:58 pm
    I have VTA boarded Mk4s and for some reason one of the 10 ohm 1/2 watt resistors is blown (the one you measure the bias across). Should I check some other areas as to why this is blown? Or just replace? I'm thinking of uping the value to 1 watt 10 ohm, good or bad idea? I've already measured all the rsistors on the board and they seem good, at least in circuit.
    Gord
    Re: Blown 10 ohm to grnd resistor on El34
    Post by GP49 on Thu Apr 21, 2011 2:07 pm
    If you had a runaway tube in that position, for whatever reason, it could have taken the resistor out.
    Pooch
    Post by Pooch on Thu Apr 21, 2011 2:43 pm
    Thanks for the quick reply.Well one of the tubes was a little red on the plate, so that must have done it. I set the bias only about a week ago. Any reason for it to go into a runaway?
    Post by tubes4hifi on Thu Apr 21, 2011 8:36 pm
    new tubes aren't made as good as the ones 30-50 years ago
    SOME EL34s I've had, especially the Mullard branded repros, do go into runaway after 5 to 20 minutes.
    The cure is to change the grid pulldown (R29-32) resistor from 270K to 220K and then reset the bias.
    The 10 ohm cathode resistor should be 1 watt
    Pooch
    Post by Pooch on Thu Apr 21, 2011 9:35 pm
    Thanks, Roy. I'm just about to pull those out to check. Mine are 220k from the original build, but I'll check them anyways, out of circuit. I replaced the blown 10 ohm resistor and it too blew after about 30 sec. Something else going on.
    I bought some 10 ohm 1/2 watt and 1 watt today. When I get it figured, I'll replace all 4 with 1 watt
    Gord
    Pooch
    bad tube
    Post by Pooch on Sat Apr 23, 2011 2:31 pm
    After checking everything, and still blowing the resistor, I changed the tube. Problem solved. Kinda strange because this bad tube checked OK on a Precision 10-12 tester.
    Luddite
    Post by Luddite on Sat Apr 23, 2011 3:52 pm
    Pooch wrote:After checking everything, and still blowing the resistor, I changed the tube. Problem solved. Kinda strange because this bad tube checked OK on a Precision 10-12 tester.
    Pooch,
    You did check for "shorts" between all of the elements, right?
    Best Regards,
    Charlie
    Pooch
    Post by Pooch on Sat Apr 23, 2011 11:23 pm
    Yep, I had, but your question got me to thinking. So I tried it again and pin 5 and 8 have a very faint glow, indicating a short. I could barely make it out, so I tried testing with another tester and this time it showed clearly. Old ears, old eyes Suspect
    Regards,
    Gord
      Current date/time is Wed May 16, 2012 7:41 pm
