    PAS3 Power Supply rebuild questions
    j4570
    Post by j4570 on Tue May 17, 2011 9:11 pm
    No that I've finished the ST70, I'd like to try to fire up the PAS3 (it's not an 3X that I can tell). However, the old quad cap and other caps look like they need to go.
    I believe it's got a 30-20-20-10 quad cap in there-appears original. I've got to read the PAS3 manual and schematic some more, but I didn't see what the value was supposed to be. Dynaco 12AX7's in the preamp too! I suspect the caps are bad.
    What's the options, I've seen a few cap boards, but what do members here do?
    Also, the selenium has to go of course.
    Pics would be great.
    Jason
    Westy56
    Re: PAS3 Power Supply rebuild questions
    Post by Westy56 on Tue May 17, 2011 9:34 pm
    j4570 wrote:No that I've finished the ST70, I'd like to try to fire up the PAS3 (it's not an 3X that I can tell). However, the old quad cap and other caps look like they need to go.
    Jason
    Hey Jason, I'll be watching this to help me on a pas refurb.
    Did you up the quad cap capacitance when you did your 70?
    Steve
    baddog1946
    Post by baddog1946 on Tue May 17, 2011 9:46 pm
    Hi:
    Check out this power supply option for the PAS 3. I like the adjustable filament voltage and tunability of it.
    http://home.comcast.net/~netminer/PAS-3.html
    j4570
    Post by j4570 on Wed May 18, 2011 3:09 pm
    Steve,
    Pics of my rebuild on my St70 are posted elsewhere on the forum. The original quad cap was toast. Matter of fact, I reused the chassis, the cage, and the output transformers. The power transformer I probably could have resued if I reinsulated the wires, but I upgraded it too.
    Jason
    j4570
    Post by j4570 on Wed May 18, 2011 3:45 pm
    I should have said I upgraded the quad cap with the CE one from Bob.
    Jason
    j4570
    Post by j4570 on Mon May 23, 2011 8:50 pm
    baddog,
    do you have a pic of that cap board installed?
    Jason
      Current date/time is Mon Apr 23, 2018 2:53 pm
