    Grounded Power Cord
    Grounded Power Cord Empty Grounded Power Cord
    Post by Guest on Fri May 20, 2011 5:05 pm
    Hi
    I've been doing some repairs on my ST-70 and I was thinking about changing the power cords on the ST-70 and my PAS-3 to the grounded type. Will this cause any problems? They will be plugged into the same grounded outlet in the house so I don't think I would have any issues with ground loops.
    Chris
    Grounded Power Cord Empty Re: Grounded Power Cord
    Post by Bob Latino on Fri May 20, 2011 5:17 pm
    Hi Chris,
    As long as you don't have another component with a 3 wire cord in your music system you should be OK. If you do have a 3 wire cord on another component you could set up a "ground loop" and pick up some hum. If this does happen just float the ground on either component with a 3 to 2 "cheater plug" and the hum should go away.
    stevenally
    Grounded Power Cord Empty Grounded line cord on a ST 70
    Post by stevenally on Thu Dec 26, 2013 9:40 am
    I am nearly done rebuilding my ST 70. I am replacing the original line cord with a IEC socket and 3 wire cord. My question is should the neutral go to the fuse or the switch? Common sense tells me to put the neutral to the switch (the part I will be handling most often) but I just want to make sure.
    Post by arledgsc on Thu Dec 26, 2013 12:48 pm
    "My question is should the neutral go to the fuse or the switch?"
    Fuse the Hot lead immediately out of the IEC jack.  The other side of the fuse goes to the switch.  Neutral connects directly transformer.  Theory being in N. America if your house is wired properly Neutral is near ground potential since it is grounded at power entry to the building or main fuse box.  This is the way UL likes to see chassis wired for best safety concerns.
    Here's a schematic that illustrates the wiring (lower right).  "L" is the Hot, Live, or Line depending up where you live.  "E" is Chassis GND or Earth.
    https://www.keepandshare.com/doc/1782400/jtm50-schematic-custom-spec-a15-1-76k?da=y&dnad=y
    Post by GP49 on Thu Dec 26, 2013 1:02 pm
    You are right. For safety, FUSE THE HOT SIDE, switch the neutral.
    Some people will point to manufacturers having fused the neutral, but for the most part that was back in the day prior to three-wire power cords, and many were GUITAR AMPLIFIERS with nothing on the outside that would be touched by a user.
    Also you may find hum from ground loop problems, once you replace the two-wire power cord on a Dynaco with a three-wire cord grounding the chassis.
    Post by sKiZo on Thu Dec 26, 2013 8:17 pm
    So, what you're saying is, if I'm not getting tossed across the room whenever I touch the metal chassis, I got it right?  What a Face
    Still a little bummed I let yall talk me out of the "floating" ground plate I was gonna add to my ST120 build. Now I'll never know if it would have worked.
    Grounded Power Cord Copper-ground-plate
    On the bright side, it does make a nice back scratcher ...
    Avinunca
    Post by Avinunca on Fri Dec 27, 2013 9:36 am
    GP49 wrote:You are right.  For safety, FUSE THE HOT SIDE, switch the neutral.
    You seem to be saying the OP should not switch the live and to switch the neutral instead.
    I would never ever use anything in a metal chassis without a safety earth and I would  switch both live and neutral with the live passing through a fuse first.
    Typical fault scenarios come to mind - neutral and live being reversed in the house wiring or some extension lead. Live touching a chassis part in the amplifier - you become the earth when you touch it.
    I would urge you to follow the advice of arledgsc but consider a double pole switch for live and neutral.
    Post by arledgsc on Fri Dec 27, 2013 12:09 pm
    "Typical fault scenarios come to mind - neutral and live being reversed in the house wiring or some extension lead"
    That is a very good point.  My garage was wired reversed until I corrected the wall sockets.  With Neutral only switched or a reversed line even when the amp is turn off you still have voltage on the power transformer input winding.  Any leakage at all may pose a shock hazard.  So switch both if unsure of your wiring or for maximum safety.
    An ungrounded chassis is actually "grounded" in use by the audio input cabling.   So any potential difference between two chassis causes current to flow in the ground leads of the audio cable.  I burned up an oscilloscope ground lead once working on an ungrounded chassis.  The AC grounded scope and unit under test were on different phases of the AC line and perhaps an air conditioner kicked on and shifted the ground potential of one of the phases.  Poof!  So if you use an ungrounded chassis keep all equipment on the same wall plug.  I never have any noise issues with my grounded chassis ST-120 and I have a noisy AC environment - CFLs, light dimmers, Insteon automation, wireless Ethernet, solar panel inverter, etc.
    PeterCapo
    PeterCapo
    Post by PeterCapo on Fri Dec 27, 2013 12:51 pm
    I actually get a lot of hum from my St-70 unless I lift its chassis ground, and I also have to lift the ground on the preamp.  Lifting both grounds eliminates the hum entirely.  Thinking out loud here... I wonder if this speaks to an issue with the wiring in my St-70?  I have the power wired as described here by arledgsc...  Everything except the TV is on the same power strip...  But, I also sometimes use Nordost interconnects, which do not have a ground shield...  I wonder if removing the 10-ohm resistor in the St-70 would help, as I would like to keep the safety ground in use all the time...
    Post by peterh on Fri Dec 27, 2013 1:20 pm
    I used an IEC well with built-in fuses, one on each lead. This saves panel space, i could
    mill the hole for the IEC right over the existing fuse.
    As regards to hum , it is more quiet when all stuff that has a ground inlet is grounded. My thorens
    do not, i don't care.
    Post by arledgsc on Fri Dec 27, 2013 3:36 pm
    " I wonder if removing the 10-ohm resistor in the St-70 would help, as I would like to keep the safety ground in use all the time..."
    That was common practice 15-20 years ago to isolate the chassis ground from the signal/ power grounds by a small value resistor.  Sometimes a ferrite bead was used in place of the resistor.  This causes a lot of EMI headaches and the practice nearly abandoned for a central or star ground scheme.   The ST-120 does this nicely with all the signal/power grounds tied together near the quad cap.  The 10 ohm resistor could be lifting the chassis potential so when three 3-prong plug is used you have a voltage difference between the amp and preamp.  And when there is a voltage difference you have current (on the interconnects).  I never liked the resistor isolation method as if it ever fried and failed you lost your ground protection.
    PeterCapo
    PeterCapo
    Post by PeterCapo on Fri Dec 27, 2013 3:54 pm
    Thanks. I will put it on my list of things to do.
    Post by Roy on Sun Jan 28, 2018 11:46 am
    sKiZo wrote:So, what you're saying is, if I'm not getting tossed across the room whenever I touch the metal chassis, I got it right?  What a Face
    hm that looks interesting though - what made you give up on it sKiZo ?!
    Post by Peter W. on Mon Jan 29, 2018 12:05 pm
    In some circumstances, altering an item away from the OEM UL-listed design will lead to a whole raft of unfortunate consequences. They are few, but significant. Pay special attention to the exclusions, conditions and requirements in your homeowners policy.
    We are going through testing the market, and why this came to my attention.
    Post by Roy on Mon Jan 29, 2018 12:08 pm
    Ah.. Yes  there is that..
    The  difference in  wording though does seem to cause some confusion, least for me lol..
    What is  commonly referred to as  'grounding' here is actually 'earthing'
    Anything that would lead to the chassis never becoming hot is   something that would have my interest.
    Post by Peter W. on Mon Jan 29, 2018 12:27 pm
    Roy D wrote:Ah.. Yes  there is that..
    Oh MY!!
    Don't (really, don't!) get me started on how chassis could get 'hot'. I worked my way through school as an electrician, and somewhat beyond as well. And my many vices - err... hobbies, includes restoring vintage radios.
    In the immortal words of Stan Lee: 'nuff said.
    Post by Roy on Mon Jan 29, 2018 12:41 pm
    Lol he keeps saying that over n over though eh ^^
    I will stick to the script when I do the 120 kit, and drop by my EE neighbour couple doors down the street for a good onceover and perhaps he has some pointers in this area of earthing.. When I showed him the tube amp last week he had 5 mins worth of gallows humor to spend on the subject XD
    Post by Roy on Sat Feb 03, 2018 11:37 am
    ..so looking at an IEC socket, its just ground to chassis hookup and hope for the best ( no hum )
    If there is hum, it may be due to the other component in the chain..
    Other components here would be class CEII with no earthing so I suppose it will be ok.
    Post by Bob Latino on Sat Feb 03, 2018 12:25 pm
    Implementing an IEC connector to an original type Dynaco chassis is not as easy as it looks. A standard IEC connector is set into the inside of the chassis by 3/4 of an inch or more. If you try to place the IEC connector where the line cord cutout is on an original Dynaco type chassis, the 3 electrical tabs on the IEC connector will bang into the bottom plate of the power transformer since the power transformer is "sunk" into the chassis at that point. One solution is to remove the fuse post and put in its place a combination IEC connector and fuse box combo. This type of arrangement is seen on many Chinese amps. See photo below ..
    Grounded Power Cord R8117235-01
    Post by peterh on Sat Feb 03, 2018 1:02 pm
    An IEC connector fits very well into the VTA-70 / vta-120 chassies. Just don't behind the
    transformer but where the fuse is located. Fuse is built-into this IEC connector.
    See http://n.manet.nu/vta70/index.html , scroll down to second picture.
    Post by Roy on Sat Feb 03, 2018 2:30 pm
    Thanks Bob, Peter!
    This month some car fixes, planting a new tree or two and fixing our shower - next month fingers crossed for my wife's ok and..
    Post by Roy on Mon Feb 05, 2018 12:37 pm
    https://www.conrad.nl/nl/schaffner-fn-9260-4-06-netfilter-met-iec-connector-met-zekering-250-vac-4-a-1-mh-1-stuks-398692.html would something like this with a built in mains filter serve much of a useful purpose, with the huge main powersupply transformer of an st-120..?
    Post by peterh on Mon Feb 05, 2018 2:22 pm
    Roy wrote:https://www.conrad.nl/nl/schaffner-fn-9260-4-06-netfilter-met-iec-connector-met-zekering-250-vac-4-a-1-mh-1-stuks-398692.html would something like this with a built in mains filter serve much of a useful purpose, with the huge main powersupply transformer of an st-120..?
    If it fits ...
    You will have to measure the space and see if it fits.
    Post by Roy on Mon Feb 05, 2018 3:24 pm
    So   this would be a good thing to put in over just a bare IEC with fuse holder  íf it fits.. Mind you this supplier has a pretty wide variety of these things with various dimensions within the same spec.
    From  what little I have managed to learn on the subject, the pretty massive input transformer of the ST-120 would  already be a pretty decent filter would it not though Peter?
    Post by peterh on Mon Feb 05, 2018 4:33 pm
    Roy wrote:So   this would be a good thing to put in over just a bare IEC with fuse holder  íf it fits.. Mind you this supplier has a pretty wide variety of these things with various dimensions within the same spec.
    Mains filter won't hurt. But it might do any difference either. The cruical part is if it
    fits inside, vta120 has an additional choke ( i think) that might interfere.
    And, a mains filter would do more if it filters preamp, sources AND poweramp.
    A barebones IEC with a fuse ( as the one i showed ) won't be longer then the fuse it replaces,
    the hard part is to make the hole, i had a friend with a milling machine do it.
      Current date/time is Tue Jul 23, 2019 10:35 am
