    Dynakit ST 35-BCU installation in a non Dynakit amp.
    Tazsmonn
    Tazsmonn
    Dynakit ST 35-BCU installation in a non Dynakit amp. Empty Dynakit ST 35-BCU installation in a non Dynakit amp.
    Post by Tazsmonn Sat Apr 16, 2011 11:39 pm
    Use of Bias control upgrade board in non Dynakit amp.
    This is for a push pull 6BQ5/ EL84 style amp. If you are not at least a minimally a seasoned hobbyist do not bother! Dynakit will not warranty this being put in a non Dynakit amp! See page 2 of the instruction manual. I will offer only the below, if you cannot “wing it” from this don’t start!
    You are solely responsible for the use and outcome of this information.
    1.Assemble the PC Board per instructions on page 7.
    2.Do steps 29- 32 page 8. Also add Green wire to the G hole.
    3.Take covers Off. Find pin #3 of the 4 6BQ5/ EL84 sockets. Remove any and all wiring from this point to ground. The two most common configurations will be all four pins will be wired to a resister to ground and it may be bypassed by a capacitor. This is how the ST 35 and The SCA35 are done. The other style is two will be connected and then go to a resistor to ground and may have a capacitor bypassing it and the other two will have the same configuration. This is how the amp I did the insulation was.
    4.The real fun begins. Find a place to mount the board so you can get all 5 wires to where they need to end up. ABCD go to the pin #3’s, AB will be V1&2 put on one channel. CD will be V3&4 other channel. G goes to the power supply ground and do make SURE it is the ground!
    5.Go back and double if not triple check everything.
    6.Go to page 9. Follow the Bias adjustment steps.
    7.You’re done and it works, Yeah!
    This is the outline of how I put the Dynakit ST 35-BCU in a receiver I rebuild. It is a SCA (never heard of them either) made in July 1963 when I was a year and a half old.
    Good luck.
    Tazsmonn
    04.16.11
    [i][img][/img]
    kevco
    kevco
    Dynakit ST 35-BCU installation in a non Dynakit amp. Empty Re: Dynakit ST 35-BCU installation in a non Dynakit amp.
    Post by kevco Tue May 03, 2011 1:21 am
    Any pictures?
    Tazsmonn
    Tazsmonn
    Post by Tazsmonn Thu May 19, 2011 11:32 am
    I have tried 3 times to get image up, I'm giving up!
    Post by Bob Latino Thu May 19, 2011 11:35 am
    Tazsmonn wrote:I have tried 3 times to get image up, I'm giving up!
    You have to host the images on another web site and link to it here. The Forum here won't host an image even though it is supposed to host an image.
    Tazsmonn
    Tazsmonn
    Dynakit ST 35-BCU installation in a non Dynakit amp. Empty Need a host site Http.
    Post by Tazsmonn Tue Jun 14, 2011 2:22 pm
    & will try again. Thanks Bob letting me know it was not my error. alien
    Tazsmonn
      Current date/time is Thu Mar 28, 2024 8:21 pm
