Hi all. After replacing my ST70's quad capacitor, the driver board, and the resistors/capacitors/selenium rectifier of the bias circuit with new ones (in kit form from dynakit.com), I'm planning also to replace all stock resistors that are remaining. I notice that V2 and V7 has a 15.6 ohm connected to their respective pins. Are these resistors with decimal value still available? If not, what should I look for? Would a 15 ohm do the job? Also, should I also pay attention to the right Watt and tolerance value for resistors that I plan to replace? Thanks for any help.
ST70 resistors replacement
Re: ST70 resistors replacement
Kevin at Dynakitparts sells replacement 15.6 ohm resistors for stock ST-70's. See link below ..
ST-70 replacement bias resistors
