    Updating a transformer for the Tung-Sol kt-120 ?
    avi.inc
    Post by avi.inc on Sat Jun 25, 2011 4:40 pm
    I found this interesting would this work on a st-120 vta?
    http://cgi.ebay.com/Harman-Kardon-Citation-II-Stereo-Tube-Amplifier-Carver-/180685645498?pt=Vintage_Electronics_R2&hash=item2a11b426ba
    Remarkable New Tube
    Several months ago the new Tung-Sol KT120 vacuum tubes became available, and I just had to try them! I found them to be remarkable - , great tubes with distortion, bandwidth, and fidelity as good as anything I have ever experienced. In order to obtain the best from these remarkable new tubes it was necessary to modify the turns ratio of the output transformer by a factor of 1.414. This lowered the impedance and optimally matched the new tubes, and I didn’t even have to alter the transformer design or change the wires inside; all I had to do was connect the external wires up in a new way such that the effective driving point impedance was optimized for these tubes.
    http://contact.ebay.com/ws/eBayISAPI.dll?ShowAllQuestions&ShowASQAlways=1&frm=284&iid=180685645498&ssPageName=PageAskSellerQuestion_VI&redirect=0&requested=audioshopper
    Q: How can you get that power at 30 hz with that iron that was at best 60 watts at that freq....And the power supply transformer with the doubler circuit was already at the limit of power. Plaease post this question and your answer . Jun-24-11
    A: Hi 'di, It's easy. Here goes, I begin. Any transformer low frequency limit is defined by the volt-time product that may be delivered to the primary winding without saturation. Since I did not change the B+ voltage one iota (It was and is 455 volts DC),and the time it takes for a 20 Hz tone to traverse one cycle remains the same (0.050 seconds) before and after the update, the volt-time product remains the same. This means the transformer low frquency limit has not changed at all. The Citation II output transformer is among the best in the world, and I was jealous of it for a long time. I could not match it at first, it having been designed by the genius Stu Hegeman. The stock transformer has a power bandwith that is well below twenty Hz, around 15 Hz or so. So how DID The output go up without running into a low frequency limit? The KT-120 tubes can pull the top of the transformer winding down about 30 volts more than the KT88 tubes. This yields slightly more output volts on the secondary winding, and by defining the taps (the ones already on the transformer) differently, we can double the power. At least in theory. The 16 ohm tap becomes the eight ohm tap, the eight ohm tap becomes the four ohm tap, and so on. And because the taps are now spaced 2-4-8 instead of 4-8-16, we get 1.414 more output volts than before. Output power is proportional to the square of the voltage, and since 1.414 squared is two, we get twice the power. Note that the secondary is completely out of the equation (except for the rms voltage output). That's just the way transformers work. At first it might seem we get something for nothing, so what's the catch? Believe it or not, there is none. The only potential difficulty is that the output tubes will see a reduced impedance and "bog" down when asked to deliver twice the power. And in fact, the KT88's DO bog severely, whereas KT120's deliver the power easily. Thanks for a GREAT question, Bob Carver.
    Re: Updating a transformer for the Tung-Sol kt-120 ?
    Post by Bob Latino on Sun Jun 26, 2011 8:18 am
    Sure - You can use the Tung-Sol KT120 output tube in the ST-120 amp. Just bias them like a KT88 at .550 volts DC per each output tube.
    Westy56
    Post by Westy56 on Sun Jun 26, 2011 8:51 am
    Much of this is over my head except the part about the citation II having good iron.
    A Citation guru told me I would need separate heater transformers to use kt120's in my deuces.
    Steve
    Post by Bob Latino on Sun Jun 26, 2011 9:08 am
    Steve,
    That may be true for the Citation II but it is not true for the VTA ST-120. The power transformer on the ST-120 is rated at a 450 milliamp current flow and handles the Tung-Sol KT120 output tubes with no problam. On an earlier post on this forum I mentioned that I ran the ST-120 with the KT120 output tubes biased at 75 milliamps per each output tube for about 3 1/2 hours. That is 20 milliamps higher than the recommended bias setting of 55 milliamps (or .550 VDC) per each output tube. The ST-120 got slightly warmer than normal at the higher bias setting but played fine. See photo below for temperature readings taken with my laser thermometer. Also check the link below about the KT120's from this forum.
    Original KT120 link
    Westy56
    Post by Westy56 on Sun Jun 26, 2011 9:27 am
    Thanks Bob, I would like to compare them to the "C" kt88's. I just don't want to blow my transformers.
    Apparently the st120 has a stout transformer. Your temperature readings seem fine to me.
    Steve
    avi.inc
    Post by avi.inc on Sun Jun 26, 2011 12:04 pm
    I guess i was not clear i know that you can use kt120"s in my ST120 I have for almost a year there great. what i was wondering was about the rewire of the output transformers for more power with out changing the B+ and if so how?
      Current date/time is Wed May 16, 2012 7:43 pm
