    KT120s & tube cages
    jhoak
    KT120s & tube cages Empty KT120s & tube cages
    Post by jhoak Thu Jul 21, 2011 4:22 pm
    Has anyone tried a set of KT120s with a stock Dynaco tube cage on a VTA/ST-120?
    I want to buy a cage for my ST-120 but I'm concerned that the extra height of KT120s might keep it from setting properly.
    THANX!
    KT120s & tube cages Empty Re: KT120s & tube cages
    Post by Bob Latino Thu Jul 21, 2011 5:07 pm
    Hi Jeff,
    The KT120's are just a hair too tall to fit inside a tube cage on the amp without the cage grazing the top glass of the tube. You have about 4 5/8 inches of clearance on the inside of a Dynaco ST-70/ST-120 tube cage. The distance from the top of the chassis to the top of the KT120 tube is also just about 4 5/8 inches. You can get the tube cage on but one or more tubes will probably be touching the inside of the perforated mesh of the tube cage. I don't recommend using a tube cage with the KT120 tubes ...
    jhoak
    Post by jhoak Thu Jul 21, 2011 5:16 pm
    That's what I wanted to know before I spent the $$
    THANX!
    Post by Bob Latino Fri Jul 22, 2011 8:08 am
    As an aside > If you use a Mullard GZ33 tube rectifier in your ST-70/ST-120, this tall tube at 5+ inches also won't fit under a tube cage.
    Regarding tube cages for Dynaco amps ... They ARE useful if you have pets or young children who may have "access" to your amps. Those tubes themselves are 300+ degrees F and will cause an instant burn if you touch a tube while the amp is running. The down side of using a tube cage are that the amp will probably run a little warmer. Yep - I know that there are perforations in the tube cage for air flow but the amp has to run a few degrees warmer with the cage on. The other downside is that the cage must be removed to reset the bias. What some tube cage users do is place the cage on the amp but don't screw it down. I don't think your cat/dog or your toddler will know enough to raise the cage by paw/hand ? To reset the bias you can just quickly remove the cage. I personally do not use a cage because I just like the looks of the tubes glowing - especially in a dimly lit room. I don't have any toddlers around anymore but Chris and I do have a cat. The cat has access to the amps but has never expressed any interest in the amps nor have I ever seen the cat walk near the amps. I guess whether you use a tube cage or not has to be a personal decision.
    If you do want a tube cage for your ST-70/ST-120 amp get in touch with Kevin at Dynakitparts. His reproduction ST-70 tube cages are extremely well made and are identical to the original ST-70 tube cages right down to the "Dynakit" label.
    jhoak
    Post by jhoak Fri Jul 22, 2011 9:11 am
    The idea has been abandoned and the person who was pushing me to adopt her cat has been told no.
    Not being able to “cage” the hot tubes was all the excuse I needed to avoid becoming a pet owner again.
    Thank you!!
    Westy56
    Westy56
    Post by Westy56 Fri Jul 22, 2011 5:26 pm
    jhoak wrote:Not being able to “cage” the hot tubes was all the excuse I needed to avoid becoming a pet owner again.
    Thank you!!
    The cages seem like a giant heating element that heats any ventilating air passing through it.
    Just guessing. Rolling Eyes
    Steve
    WntrMute2
    WntrMute2
    Post by WntrMute2 Sat Jul 23, 2011 7:20 am
    Bob, is that a picture of you and your SO in your avatar?
    Post by Bob Latino Sat Jul 23, 2011 8:17 am
    WntrMute2 wrote:Bob, is that a picture of you and your SO in your avatar?
    Yes - The avatar is myself and my wife (#3), Chris. It was taken at a beach by my wife's cousin. Chris is quite a bit younger than me (16 yrs). I still wonder what she sees in me ?
    Wife #1 and I parted company in 1997. I had two jobs at the time. She didn't like the fact that I would use some of my second (part time) job money to buy audio gear - SO - I used the extra money on a divorce lawyer instead.
    Wife #2 (1999 - 2004) sadly passed away from cancer on May 19th of 2004.
    Wife #3 (Chris) and I met though a mutual friend.
    buchela
    Post by buchela Sat Jul 23, 2011 2:31 pm
    Ok BOB, no more second jobs.lol
      Current date/time is Thu Mar 28, 2024 7:28 pm
