    Mark III Driver Board - R16 Question
    SoundBound
    Post by SoundBound on Tue Aug 02, 2011 10:29 am
    Started putting the components on my Mark III VTA driver boards and came across something that has me guessing.
    In the parts list R16 (6.8K) is listed only as a 1/2W resistor, yet I wonder if this is not supposed to be a 2W rated resistor similar to the other resistors in this part of the circuit (ie R20 R22)?
    Can anyone confirm the correct wattage for this resistor?
    Thanks. SoundBound
    snav
    Re: Mark III Driver Board - R16 Question
    Post by snav on Tue Aug 02, 2011 11:11 am
    I have seen that listed variously as 1w or 2w but never less. I would err on the side of the larger rating especially with newer resistors being smaller than vintage Carbon Comp.
    Post by Bob Latino on Tue Aug 02, 2011 11:33 am
    Roy Mottram can correct me if I am wrong BUT > I believe the confusion about R16 may be because on the VTA Mark III standard gain board that uses 12AT7 driver tubes > R16 is a 6.8K 1/2 watt resistor. On the LOWER gain board that uses 12AU7 or 12BH7 driver tubes R16 is a 6.8K 1 watt resistor. That resistor does not have to be a 2 watt resistor.
    SoundBound
    Post by SoundBound on Tue Aug 02, 2011 12:50 pm
    Thanks Bob and Snav;
    I am building the lower gain version with the 12AU7s, so it makes sense to me that the 1/2w resistor is a bit low, I will go ahead and substitute a 1W or better for the 6K8. Maybe if Roy sees this post he can correct the documentation for the low gain version.
    Post by tubes4hifi on Tue Aug 02, 2011 1:50 pm
    yes, should be a 1 watt, if I sent you the wrong part email me directly and I'll send you the correct part
    Roy info@tubes4hifi.com
    SoundBound
    Post by SoundBound on Tue Aug 02, 2011 2:51 pm
    Hello Roy,
    I purchased the bare boards, supplied my own parts. The confusion is in the documentation (VTA MK3 v11 LG manual.pdf) for the low gain configuration, R16 does not have a wattage specified in the parts list, thus as per all other resistors where wattage is not specified, 1/2 watt is understood to be the wattage value. This is the error, it should be marked as a 1 watt (according to Bob and Roy).
    Post by Bob Latino on Tue Aug 02, 2011 2:58 pm
    SoundBound wrote:Hello Roy,
    I think that the "LG" in the manual name > (VTA MK3 v11 LG manual.pdf) means LOW GAIN. If that is the case, then you need a 6.8K 1 watt resistor - not a 6.8K 1/2 watt resistor.
    Post by tubes4hifi on Tue Aug 02, 2011 7:59 pm
    Bob is correct, and I have updated the manual to show that resistor is a 1 watt
      Current date/time is Wed May 23, 2018 1:26 am
