    can i simply plug a WZ-68 weber copper cap into my stock dynaco st 70 ? OR ...
    pscottlowe
    Post by pscottlowe on Sun Sep 04, 2011 10:14 pm
    do i need something else too .My 5AR4/GZ34 just went out so would i be better to replace it ? thank you
    pscottlowe
    Post by pscottlowe on Sun Sep 04, 2011 10:27 pm
    are changes needed to my two st-70's ? or does it need modification ? all i know is it sends power faster than the tube and that may do fillament damage ? THX Scott {new member}
    Sal
    Re: can i simply plug a WZ-68 weber copper cap into my stock dynaco st 70 ? OR ...
    Post by Sal on Sun Sep 04, 2011 11:32 pm
    I have not used a Weber copper cap but what little I know about them is there is a slight warm up time, maybe not as long as a 5AR4. The B+ might come on a little soon so your 525V rating of the quad capacitor might be exceeded for a few second.
    The only thing you might have to do is readjust the bias.
    I am sure Bob will chime in as he uses the Weber copper caps in his amplifiers.
    Sal
    Post by Bob Latino on Mon Sep 05, 2011 6:48 am
    The Weber WZ68 solid state rectifier is safe to use in any Dynaco ST-70 or the VTA ST-70, ST-120 or M-125 monoblocks. The Weber plugs right into the rectifier's tube socket and just replaces the tube rectifier. The Weber has a 3 to 5 second delay before high voltage is supplied so it simulates (somewhat) the delay of a GZ34 tube rectifier warm up. A tube rectifier does have a longer (20 seconds or so) delay.
    The Weber WZ68 can flow double the amount of current as a GZ34 tube rectifier and is recommended if your amp has a difficult speaker load to drive OR if you play the amp at pretty loud volumes a lot.
    The amp must be rebiased when you switch from a tube rectifier to the Weber.
    Some old timers scoff at "using a solid state rectifier" but all the major manufacturers of modern tube amps like McIntosh, Conrad Johnson, BAT, Rogue etc. all use hard wired solid state rectifiers. Solid state rectifiers give a higher forward flow and do give a higher B+ voltage. If your ST-70 measured 430 volts off pin 8 of the rectifier tube with a TUBE rectifier, it will probably now measure 445 volts off pin 8 with a solid state rectifier. This is the reason that the amp must be rebiased every time you change from a tube to a solid state rectifier (or vice versa).
    anbitet66
    Post by anbitet66 on Mon Sep 05, 2011 10:00 am
    Bob,
    I have to chime in here.
    I read all over the internet with interest how so many non-engineer tube types say how a rectifier so significantly changes the way an amp sounds (usually because it's now a vintage Mullard which costs hundreds of dollars). I have an electronics background, and I can say what I learned in the early 1980's applied to tubes,transistors, and ic's. The power supply in any well designed piece of equipment must provide a stiff voltage from idle to full output. The spec was usually 10% regulation or better. This was irrelevant weather the rectifier was solid state or a tube. How a rectifier makes such a significant difference in the sound of a properly designed amplifier is a mystery to me.
    If the power supply was marginal, the addition of silicon diodes may help slightly. The use of them in an amplifier that was working properly would make little difference at best since the power supply was properly able to supply the needed voltages under all conditions with a tube rectifier.
    Not to mention, there were many designs "back in the day" that used diodes in a good design. Take my Pioneer SX-34b receiver. It uses a voltage doubler circuit with diodes. The full voltage is available immediately. By no means does it sound like a solid state amp. It is as "tubey" as any i've heard.
    End of rant.
    To Scott:
    1) Drop in the WZ68.
    2) Reset the bias.
    3) Enjoy your amp.
    Very Happy
    Tony
    Blitzen
    Post by Blitzen on Mon Sep 05, 2011 10:38 am
    Just to point out something not always obvious when reading and digesting tube literature on the web-
    There's a divide between tube amps being used for hi-fi and those for guitar and other instrument amplifiers. Especially when used as guitar amps, some of the tubes and circuitry are pushed to their limits; indeed PAST their limits! As such, different rectifier tubes or SS can sound differently.
    Note that an amplifier can become something more than "just an amplifier"; it is part of the instrument itself.
    anbitet66
    Post by anbitet66 on Mon Sep 05, 2011 11:41 am
    Ok,
    Blitzen is correct. If you push an amplifier beyond its limits there will certainly be a difference in sound. My education didn't include guitar amplifiers, and were not taken in to consideration in my above rant Embarassed . But, when there is talk of changing a rectifier to alter sound quality in a garden variety amp be it Dyanco, McIntosh, Scott, Realistic, Lafayette, etc... I stand by my education and more importantly my ears. Keep in mind this is just my opinion. What do I know Rolling Eyes ?
    Tony
    Westy56
    Post by Westy56 on Mon Sep 05, 2011 11:55 am
    anbitet66 wrote:Not to mention, there were many designs "back in the day" that used diodes in a good design. The full voltage is available immediately. By no means does it sound like a solid state amp. It is as "tubey" as any i've heard.
    End of rant.
    Very Happy
    Tony
    Yep, my citation II's and I think my mc240.
    There is nothing "tubey" sounding with the citations though.
    The 240 is another story.
    Steve
    Post by GP49 on Mon Sep 05, 2011 10:05 pm
    On an old amplifier, if the power supply CAPACITORS are marginal, the silicon diodes may finish them off.
    The reason: the process of "forming" the electrolytic dielectric layer in a capacitor is voltage-reliant; that is, if your
    capacitors have been seeing 480 volts for umpteen dozen years and you put in a silicon rectifier, the capacitors
    will "see" 500 volts or so, all of a sudden. But in effect, for all these years, even if the can is stamped "525 WVDC",
    the electrolyte has actually "formed" for a working voltage of 480 volts. A new capacitor, or one in good condition,
    with fresh electrolyte, will re-form itself to the new voltage. But an old, worn, dried out one may not, the result being
    an arcover.
    At the very least, bring the voltage up slowly with a VariAC or equivalent, the first time you fire up the amplifier with
    its new silicon rectifiers. That will give the capacitors a fighting chance.
    j4570
    Post by j4570 on Tue Sep 06, 2011 8:23 am
    Also,
    I can't seem to search right now, but I posted a while back Weber's response regarding the difference between WZ34 and a WZ68, and in an ST70, it seemed it might be better to stick with the WZ34. I think it had to do with the warm up time changed with current flow. Probably not a big deal, but something to check out.
    Use Advanced Search on my id "j4570" and "weber" and see what comes up.
    j4570
    Post by j4570 on Tue Sep 06, 2011 9:17 pm
    Now at home, and can search, here is the link:
    http://dynacotubeaudio.forumotion.com/t489-wz34-vs-wz68-weber-copper-cap
    Looks like the WZ34 would give more "sag" earlier, mimicking the original tube more, the WZ68 would be an improvement. I doubt there would be much difference, but since I don't run one yet, I am not the one to offer a real-world opinion.
    Heed GP49's warning, this could be a good way to toast a marginal or old can cap. Also, if it's original, does that mean you have a selenium rectifier too? Just waiting to go up in smoke, literally.......might be time for a little updating, at least in the power supply section, for safety's sake.
    I want you to get that ST70 back up and running, but safely.
      Current date/time is Wed May 16, 2012 7:44 pm
