    st-70 blew fuse and rectifier while setting the bias
    pscottlowe
    Post by pscottlowe on Mon Sep 19, 2011 1:28 pm
    i just replaced a blown rectifier and while setting bias the new rectifier blew and the fuse also went at same time . i pulled the fuse and upon inspection i noticed the fuse was only rated at .5 amp / 240 vp. and i think it should be 3. amp . is this common that this could happen or should i take it to a tech?
    DynakitParts
    Correct Fuse
    Post by DynakitParts on Mon Sep 19, 2011 2:46 pm
    The correct fuse rating for the ST-70 operating @ 240 vac would
    be 1.5 amps...This should be a SloBlo type fuse. Also referred to
    as a time delay fuse.
    If this size fuse blows...then it time to find a tech.
    Kevin @ Dynakit
    pscottlowe
    Re: st-70 blew fuse and rectifier while setting the bias
    Post by pscottlowe on Mon Sep 19, 2011 8:41 pm
    thank you i replaced the fuse and rectifier and reset bias and its running very well thank you .
    Post by j beede on Mon Sep 19, 2011 9:50 pm
    I run 3A slo-blo in the Mark III and ST-70.
      Current date/time is Tue Feb 20, 2018 3:44 pm
