i just replaced a blown rectifier and while setting bias the new rectifier blew and the fuse also went at same time . i pulled the fuse and upon inspection i noticed the fuse was only rated at .5 amp / 240 vp. and i think it should be 3. amp . is this common that this could happen or should i take it to a tech?
st-70 blew fuse and rectifier while setting the bias
pscottlowe- Posts : 37
DynakitParts- Posts : 215
Correct Fuse
The correct fuse rating for the ST-70 operating @ 240 vac would
be 1.5 amps...This should be a SloBlo type fuse. Also referred to
as a time delay fuse.
If this size fuse blows...then it time to find a tech.
Kevin @ Dynakit
Kevin @ Dynakit
thank you i replaced the fuse and rectifier and reset bias and its running very well thank you .
j beede- Posts : 473
I run 3A slo-blo in the Mark III and ST-70.
