    pas 3 / pas 3x how to ID
    pscottlowe
    pas 3   /   pas 3x  how to ID Empty pas 3 / pas 3x how to ID
    Post by pscottlowe on Sat Oct 01, 2011 5:56 pm
    how do i tell if i have a pas 3 or a pas 3x ?
    BrianLW
    BrianLW
    pas 3   /   pas 3x  how to ID Empty Re: pas 3 / pas 3x how to ID
    Post by BrianLW on Sat Oct 01, 2011 7:36 pm
    The 3x has a treble control with a gap (no connection to wiper) at the center (flat) position. I believe you could measure the resistance between the the 2 end lugs of a treble control and if you get around 400k it's a 3 and if it measures open you have a 3x (or a faulty pot). I no longer have a Dyna Pas3x to test, so I'm sorry I can't try this out for you. If I'm way off the mark, I'm sure someone will come alone and correct me!
    Sal
    Sal
    Post by Sal on Sat Oct 01, 2011 11:56 pm
    Check the rotation of the bass and treble controls vs. the volume control, if the amount of rotation is the same, you have a PAS-3, if the treble and bass controls rotation is less, you have a PAS-3x. For example, if the rotation of the volume control is 300 degrees and the rotation of the tone controls is approx 240 degrees, you have a PAS-3X. There are also 1uf capacitors going from the tone controls to the printed circuit boards on a PAS-3X.
    Regards,
    Sal
    pscottlowe
    pas 3   /   pas 3x  how to ID Empty pas 3 and ST-120 compatable ?
    Post by pscottlowe on Sun Oct 02, 2011 2:14 pm
    Hi I want to upgrade from my ST-70 to a VTA ST-120. I have a pas 3 [not pas 3 x ] and i want to make sure that the output of my pre amp will drive the VTA ST-120 without bass rolloff? I use a pair of Klipsch LaScalla and want more power.and I want to confirm that they will work together well. Thank you guys for all your help.Scott
      Current date/time is Tue Nov 12, 2019 4:08 pm
