    ST70 rebuild, hard-wired
    rovano
    ST70 rebuild, hard-wired Empty ST70 rebuild, hard-wired
    Post by rovano on Mon Oct 03, 2011 11:33 am
    Hi everyone,
    I am new to this forum and want to share my efforts in rebuilding a ST70 amplifier.
    I bought a stock ST70 (1961) on EBay that looked like this:
    ST70 rebuild, hard-wired Foto-F7RCLNAF-D
    I completely stripped the amp and cleaned the chassis:
    ST70 rebuild, hard-wired Foto-YEXLNS87-D
    I did not change the original topology of the amp except for the power supply.
    The power transformer was replaced by a Triode Electronic transformer.
    I needed a 230V version anyway, so I decided to buy a beefier transformer instead.
    Modified the multicap for the 80-40-30-20 version of Dynakit and replaced
    the selenium cell for an ultrafast rectifier diode type BYV29.
    All other components are new except for the chassis, the A470’s,
    the choke,  the speaker connectors, the bias pots and the cathode resistors.
    I used Belton tube sockets (except for the sockets up front that are still the
    original Amphenol sockets), resistors are Beyschlag (red brown ones),
    Takman and Kiwame (green). All carbon types. For coupling I used Auricap capacitors.
    Tubes used: a matched quad JJ EL34L, Silvania and/or RCA 7199, Philips nos GZ43.
    The mono-stereo switch was left unused.
    Most rebuilds are done using PCB’s for the front end of the amp.
    I disliked the PCB on top, so I decided to follow another approach.
    You hardly ever see a hard wired  ST70, so I fully hard wired the frontend using
    stand offs, terminal strips and a sub chassis that is covered with a laser-cut
    chrome steel plate on top. First attempt sub chassis:
    ST70 rebuild, hard-wired Foto-D4QT4AA7-D
    This one worked fine but I was not completely satisfied.
    I used this one for another ST70 that I rebuild for my brother.
    I thought it over and designed a less chaotic topology.
    Layout of the final version of the front-end:
    ST70 rebuild, hard-wired Foto-ZJAGAS3G-D
    Dimensions (in millimeters) of the sub chassis:
    ST70 rebuild, hard-wired Foto-PKQQD3U6-D
    Dimensions (in millimeters) of the cover:
    ST70 rebuild, hard-wired Foto-SNHNSLTP-D
    Top view of the completed ST70:
    ST70 rebuild, hard-wired Foto-HGYLU7NE-D
    This is how it looks underneath:
    ST70 rebuild, hard-wired Foto-3XVL7WGQ-D
    Some detail shots:
    ST70 rebuild, hard-wired Foto-RVFYRS7K-D
    ST70 rebuild, hard-wired Foto-FHMPQRN3-D
    ST70 rebuild, hard-wired Foto-V84RJMGB-D
    Comments and critics are welcome.
    Those of you who might be interested in (re)building the ST70 this way,
    may benefit from this layout. Mail me and I will send you the drawings
    in PDF format, or if so desired, in Autocad DWG format.
    All drawings are in a 1 to 1 scale.
    See also my triode - ultra lineair mod., Post n°35:
    http://dynacotubeaudio.forumotion.com/t41p25-run-your-dynaco-st-70-mark-ii-mark-iii-or-mark-iv-in-triode-mode-photo
    Here are the two finished ST70’s and my ‘Classic One’ preamp:
    ST70 rebuild, hard-wired Foto-7YKXUYM6-D
    The Classic One is the incredible sweet sounding design of
    Triode Dick consisting of a SRPP stage (6N30) and
    a cathode follower stage (6N6) and here it is:
    http://www.triodedick.com/pdf_files_td/Classic%20One.pdf
    If you want to know more about this beauty, mail me.
    All ST70 photos (click on the photo displayed in the
    center for a larger view) can be found here:
    http://www.mijnalbum.nl/Album=J4WJS6CU
    At this time I (temporarily) replaced my ST70 for the Allen Wright's PP-2C power amps (monoblocks)
    Text on this forum is all in Dutch, but there are a lot of photos and schematics, if you’re interested. Use Google Translate.
    Last edited by rovano on Sun Mar 24, 2019 7:48 pm; edited 6 times in total (Reason for editing : Addition of links)
    willieher
    ST70 rebuild, hard-wired Empty Re: ST70 rebuild, hard-wired
    Post by willieher on Sat Oct 08, 2011 7:58 pm
    Man you must enjoy soldering !!!!!!! I have a rebuilt ST-70 here under willieher and as much as I enjoyed my rebuild I would never attempt the rebuild you did. I think you did an excelent job.
    I dont post very often but when I see extencive work on a driver board like this I had to
    say something. You must enjoy the sound of carbon resistors over metal film. I have added
    2 Riken carbon resistors in the signal path to add a little noise, I have also changed the 4 output caps To Mundorf Silver in Oil. My amp sounds a lot better now.
    Willie...
    rovano
    Post by rovano on Sun Oct 09, 2011 6:05 am
    Yeah, I don’t mind a little soldering.
    Saw your amp too and it is clear that you don’t mind to experiment. Nice job, Willie!
    I wanted to rebuild my ST70 to stock, but as always with the kind of breed audiophiles are,
    I am planning to build another ST70 with a completely other setup.
    Just to see and experience the difference in sound. (and because I like to solder!)
    I may even want to experiment with metal film resistors and a solid state bias adjustment system.
    Maybe I will try a SRPP frontend as in my Classic One preamp, don’t know yet.
    Of course this amp is also completely hard wired:
    http://www.mijnalbum.nl/Album=WTZPO3OZ
    I think that point to point wiring is the way to go in glass sound, but I am probably a bit nostalgic here.
    I am quite pleased with the combination of these two amps, but there is always room for improvement.
    Thanks for your reaction,
    Roland
    willieher
    Post by willieher on Sun Oct 09, 2011 8:07 am
    Hi Roland, speaking of GLASS I have been rooling some power tubes
    and I have come across and am curently using a quad of NOS Russian 6n3ce
    there not expensive, and these things sound sweet.
    Good luck on your next project.
    Willie...
    rovano
    Post by rovano on Sun Oct 09, 2011 8:57 am
    Thanks Willie,
    Before I start with this new project, I first have to restore two Dynaco FM3 tuners.
    Still looking out for a replacement power supply transformer (230V), by the way, so if anyone has a tip for me, I would be much obliged.
    (maybe I will hard-wire one of them too!)
    Then I have to build a SET amplifier based on the Decware model SE84C of which I have all the components in store,
    I still have to modify my AVO CT160 tube tester and on top of that,
    I am planning to build a short wave receiver (ARRL 1963 Simplex Super), so I have a lot to do.
    I have tried the 6N3CE myself, but I found these inferior to the EL34.
    But that is purely my personal opinion of course.
    Oh, I forgot to mention, I have got my ST70 hooked up on a pair of Tannoy Cheviot speakers.
    I find these speakers very suitable in combination with tube amps.
    Is there someone else here with experience of the famous Tannoy sound?
    Roland
    cpbajan
    ST70 rebuild, hard-wired Empty classie one preamp
    Post by cpbajan on Mon Oct 24, 2011 8:57 am
    Interested in your Classic one preamp. Do you have complete schematics that you can share.
    rovano
    Post by rovano on Mon Oct 24, 2011 1:26 pm
    Schematics Classic One:
    http://www.triodedick.com/classic_1/classic_one_schema_versterker.GIF
    http://www.triodedick.com/classic_1/classic_one_schema_voeding.GIF
    I also made elaborate drawings of this amplifier. If you want I can mail them to you.
    This amp uses double powersupply!! Transformers are made in the Netherlands by AE schagen:
    http://transformatorspecialist.shoplin.nl/pd-27033-7-53881/product/classic_one.html
    cpbajan
    Post by cpbajan on Mon Oct 24, 2011 10:04 pm
    Thanks for responding. Would like to see the drawings, but can't send external links yet as i am new to forum. Would like to hear about your dual power supply also.
    rovano
    Post by rovano on Tue Oct 25, 2011 1:52 pm
    You’re welcome.
    This preamplifier can be seen as a pair of monoblocks, which means that both channels are completely separated including the power supply section(s).
    It will all become clear when you study the photos of this project:
    Because you are new here, I am not able to mail you because your address is not visible for me.
    In a week or so I will mail you my drawings.
    cpbajan
    Post by cpbajan on Tue Oct 25, 2011 5:59 pm
    Wow, those are very nice. I, like you, am modifying a ST70, but wanted something a bit more than a modded Pas 3. I will wait the week so you can send me the drawings
    rovano
    Post by rovano on Wed Oct 26, 2011 5:49 am
    Wow? This is just how it looks. Wait until you HEAR this baby.... Very Happy Surprised
    rovano
    Post by rovano on Sun Mar 24, 2019 6:34 pm
    Measurements of my ST70 in triode mode:
    Square wave respons 1kHz:
    ST70 rebuild, hard-wired 1khz_t11
    Square wave respons 10kHz:
    ST70 rebuild, hard-wired 10khz_12
    Square wave respons 20kHz:
    ST70 rebuild, hard-wired 20khz_13
    Frequency response:
    ST70 rebuild, hard-wired Freq_r10
    THD+N vs Frequency, 1W:
    ST70 rebuild, hard-wired Tndn_v12
    THD+N vs Frequency, 10W:
    ST70 rebuild, hard-wired Tndn_v10
    THD+N vs Frequency, 15W:
    ST70 rebuild, hard-wired Tndn_v13
    THD+N vs power:
    ST70 rebuild, hard-wired Tndn_v18
    rovano
    Post by rovano on Sun Mar 24, 2019 6:47 pm
    Measurements of my ST70 in UL mode:
    ST70 rebuild, hard-wired 1khz_u11
    ST70 rebuild, hard-wired 10khz_13" />
    ST70 rebuild, hard-wired 20khz_14
    Frequency response:
    ST70 rebuild, hard-wired Freq_r11
    ST70 rebuild, hard-wired Tndn_v14
    ST70 rebuild, hard-wired Tndn_v15
    THD+N vs Frequency, 30W:
    ST70 rebuild, hard-wired Tndn_v16
    THD+N vs power:
    ST70 rebuild, hard-wired Tndn_v17
      Current date/time is Thu May 23, 2019 7:59 am
