    Thanks To Bob For His Review
    Jim McShane
    Thanks To Bob For His Review Empty Thanks To Bob For His Review
    Post by Jim McShane Fri Nov 04, 2011 6:09 pm
    ...of the KT120 Tung-Sol tube. It's posted in another forum, and it might be good to post it here too if you don't mind Mr. Latino.
    Bob did a nice job of describing the sonic differences between the KT-88 and the KT-120, rather than just talking about the mechanical and electrical differences. The differences he describes ("tubier" in particular) are often the results of differing distortion spectra between two tube types - and the curves on the two tubes seem to confirm that as the likely reason for the difference.
    Also, FWIW I've had zero problems with them in the short time I've had them. That's always a good thing!!
    Thanks again Bob!
    WntrMute2
    WntrMute2
    Thanks To Bob For His Review Empty Re: Thanks To Bob For His Review
    Post by WntrMute2 Fri Nov 04, 2011 7:02 pm
    Linky, Link?
    Jim McShane
    Thanks To Bob For His Review Empty Here you go:
    Post by Jim McShane Fri Nov 04, 2011 10:17 pm
    zx
    Thanks To Bob For His Review Empty Kt88 orKT120 just diff.
    Post by zx Sat Nov 05, 2011 7:26 am
    As for the Kt12o at $200 for a quad an a good KT88 at $110 for a quad,there not more than just a diff tube....Now if you ging to put 600-700VB+ on the plate, the 120 may be the way to go.... The AR tube amps Most all run at 440VB+ on the plates...An i to think this sounds best it a sweet spot... I have drop my MK3s down to 450VB+ sound is much more tubey.With the AR amps that have always sounded to me,On the bright side the 120 helps but i dont hear the diff in cash... Mybe for most it just money...Just one mans o-pine
    Thanks for the site Bob
      Current date/time is Thu Mar 28, 2024 5:51 pm
