Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 4055 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 829 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1341 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
Pre-Order Questions for the PH16 Phono Preamp | 4 | tlarwa | 2776 | Wed Feb 13, 2019 6:16 pm by Roy Mottram | ||
Review of VTA ST-120 After One Year Listening | 11 | EddieGnz1 | 8121 | Wed Feb 13, 2019 11:58 am by corndog71 | ||
Dynaco ST-35: My experience buying and restoring. | 4 | crkohut | 798 | Mon Feb 11, 2019 5:13 pm by Peter W. | ||
Applications for A-441 OPT/amp schematics | 3 | stromberg67 | 936 | Sun Feb 10, 2019 6:35 pm by stromberg67 | ||
If you are going to troubleshoot tube amps > Get a capacitor meter | 9 | Bob Latino | 1969 | Sun Feb 10, 2019 9:52 am by Big Harry | ||
The Humble #53 Lamp | 8 | Peter W. | 916 | Fri Feb 08, 2019 4:05 pm by Peter W. | ||
Dynaco Updates Mods Restoprations | 7 | Tuninfork | 1439 | Fri Feb 08, 2019 3:29 pm by sKiZo | ||
VTA ST70 or 120 for JBL 4312SE 91db | 17 | mati1979 | 1493 | Fri Feb 08, 2019 1:32 pm by jimzim429 | ||
[ Poll ] Basic Safety | 8 | Peter W. | 829 | Thu Feb 07, 2019 5:09 pm by Peter W. | ||
[ Poll ] On the Dynaco OEM PAS Series | 7 | Peter W. | 1060 | Thu Feb 07, 2019 10:52 am by Peter W. | ||
New VTA ST-120 | 1 | ImFritz | 797 | Wed Feb 06, 2019 12:16 am by Dogstar | ||
Dynaco MKII Troubleshooting | 22 | drafalske | 1701 | Tue Feb 05, 2019 9:58 am by drafalske | ||
Reccomendations for a Diy Dac | 9 | ImFritz | 1131 | Tue Feb 05, 2019 9:17 am by cci1492 | ||
SP14 mechanical hum. | 7 | FearOfMusic | 965 | Mon Feb 04, 2019 4:34 pm by FearOfMusic | ||
Auto-bias board and a Weber WS1 | 23 | Kramer | 3399 | Mon Feb 04, 2019 5:38 am by Guest | ||
Pic test with Max | 6 | ImFritz | 587 | Sat Feb 02, 2019 5:30 pm by ImFritz | ||
Ok ok ok I think Ive got this | 0 | ImFritz | 758 | Sat Feb 02, 2019 7:57 am by ImFritz | ||
ST-120. Which tap for which configuration. | 1 | bbqjoe | 546 | Fri Feb 01, 2019 8:01 am by Peter W. | ||
SCA-35 Front Panel Wiring Pictorial | 3 | stewdan | 554 | Thu Jan 31, 2019 5:36 pm by stewdan | ||
Turn on and turn off procedure | 8 | ImFritz | 789 | Thu Jan 31, 2019 9:23 am by Peter W. | ||
Info or circuit diagrams on Melos modded Dynaco MK 4 | 18 | miniaussie | 901 | Tue Jan 29, 2019 2:00 pm by Peter W. | ||
Desoldering station recommendations? | 14 | vtshopdog | 1217 | Sat Jan 26, 2019 4:03 pm by BNR_1 | ||
New Member | 12 | Cav Trooper | 943 | Sat Jan 26, 2019 12:10 pm by Cav Trooper | ||
Subwoofer tube amplifier? | 2 | bbqjoe | 809 | Fri Jan 25, 2019 4:00 am by pichacker | ||
Statistics | 18 | Dogstar | 980 | Thu Jan 24, 2019 3:24 pm by bbqjoe | ||
PH-16 Tube rectifier vs diode mod | 3 | mdelrossi | 800 | Wed Jan 23, 2019 7:25 pm by Roy Mottram | ||
ST-70 driver board cover installation shortcut | 7 | fmorelli | 828 | Mon Jan 21, 2019 1:38 pm by Peter W. | ||
The SP14, mechanical isolation and you. | 10 | bbqjoe | 871 | Sun Jan 20, 2019 2:25 pm by bbqjoe | ||
ST120 Quad Cap Voltage Rating | 2 | mazeeff | 932 | Fri Jan 18, 2019 1:37 pm by mazeeff | ||
Psvane KT-88's | 1 | mhardyman | 644 | Thu Jan 17, 2019 5:51 pm by peterh | ||
SP14. Has anyone got a solid pic of the AC, fuse and terminal wiring? Help please. | 13 | bbqjoe | 1201 | Thu Jan 17, 2019 4:44 pm by Jedidiah | ||
SCA-35 Selector Switch | 24 | Tom_Johnson | 2319 | Thu Jan 17, 2019 3:23 pm by Tom_Johnson | ||
Adding meters to a SP14. | 7 | FearOfMusic | 957 | Mon Jan 14, 2019 1:23 pm by Peter W. | ||
Balanced power | 9 | FearOfMusic | 809 | Sun Jan 13, 2019 6:35 pm by peterh | ||
Starting first restore 1, 2 | 46 | ttownscott | 3305 | Sun Jan 13, 2019 6:18 pm by ttownscott | ||
ST70 with new VTA Board (12AU7) upgrade question/problem? | 3 | tgrier | 934 | Sat Jan 12, 2019 2:24 pm by tgrier | ||
ST-70 6B4G | 6 | ronton3 | 1089 | Sat Jan 12, 2019 2:04 am by ronton3 | ||
Issues with M125 after Auto Bias install 1, 2 | 47 | Skydogcable | 4699 | Fri Jan 11, 2019 6:25 pm by Roy Mottram | ||
PH16XW NoiseFloor/Hum 1, 2 | 28 | Skydogcable | 2060 | Fri Jan 11, 2019 2:45 pm by Roy Mottram | ||
Bucking Transformer | 4 | Peter W. | 1490 | Thu Jan 10, 2019 11:28 am by cci1492 | ||
Need help with auto bias board malfunction 1, 2 | 35 | kevinmi | 3915 | Thu Jan 10, 2019 3:57 am by pichacker | ||
5V AC Filiment Voltage On Amp With Solid State Rectifier | 7 | mazeeff | 682 | Wed Jan 09, 2019 1:26 pm by Guest | ||
Purpose of chokes | 11 | wildiowa | 1568 | Tue Jan 08, 2019 2:51 pm by DarthBubba | ||
Is there a 12VDC source on the ST-120 | 24 | bbqjoe | 700 | Tue Jan 08, 2019 1:45 pm by aguaazul | ||
ST120 completed | 17 | mikescaggs | 1052 | Tue Jan 08, 2019 2:55 am by bbqjoe | ||
Experience with Maggies or other planar (including ML electrostatics). | 21 | Guest | 1262 | Mon Jan 07, 2019 11:08 pm by Guest | ||
122v and above - why not address the issue? | 22 | dalemurray | 1502 | Mon Jan 07, 2019 11:24 am by cci1492 | ||
VTA ST-120 Speaker problem - solved ! | 10 | sandeep dutta | 1380 | Sat Jan 05, 2019 1:27 pm by sandeep dutta | ||
Dynaco MKIII high B+ 5U4 low bias | 2 | ronton3 | 560 | Sat Jan 05, 2019 9:46 am by ronton3 | ||
Help with ST-120 custom build | 0 | ureche | 608 | Fri Jan 04, 2019 5:23 pm by ureche |
Sort
Users browsing this forum: 1 Registered, 0 Hidden and 4 Guests
Registered Users: peterh
