Hi, i was wondering what rating should a switch in the b+ should have? for the ST120 amp. I see most of them are rated for 250vac and ST120 has a b+ of ~500vdc. With ss has about 520vdc.
What i was thinking, is to add the option to switch between solid state and tube rectifier, without adding additional resistance to power supply (like wz68). In order to keep the voltage to the driver board between 370v-400v, i need to change the drop resistor from power supply. I was thinking to add a ON/ON switch, so i can change between resistors. I won't act the switch while the amp is on.
