Same tube keeps going bad
MechEngVic- Posts : 106
- Post n°1
I have a Dynaco ST-70 Series II amp. The V5 position keeps blowing tubes. It's not a connection or solder issue, they have been gone over multiple times and tube sockets have been replaced. This has happened before and is happening after a major rebuild. The only thing not new is the transformer. Voltages are all within spec and so is the bias. Can an old beat up output transformer cause a tube to go bad?
Re: Same tube keeps going bad
I wanted to add that the output transformers are A470's
I also wanted to add that the tube arcs during warm-up, not right away but several seconds to over a minute into it. Arcing during warm-up is the failure that is happening. It happens once, then it doesn't arc for several hours of use and several on and off cycles. Then it will do it again and again with increased frequency. Now that I see the pattern, I don't let it happen more than a couple of times before I replace the tube. Then all is well for many dozens of hours and many dozens of on and off cycles before it does it with the new tube.
peterh- Posts : 1823
Arc-ing is a symptom of something really bad.MechEngVic wrote:I also wanted to add that the tube arcs during warm-up, not right away but several seconds to over a minute into it. Arcing during warm-up is the failure that is happening. It happens once, then it doesn't arc for several hours of use and several on and off cycles. Then it will do it again and again with increased frequency. Now that I see the pattern, I don't let it happen more than a couple of times before I replace the tube. Then all is well for many dozens of hours and many dozens of on and off cycles before it does it with the new tube.
Looking at the schematics , screen stoppers are missing, maybe the grid stoppers are too far from
the tube to be of value. DO install these ( carbon comp, soldered close to the socket. 100 ohm
for the screens, 1k for the grids).
If this don't stop the arcing , a few turns of a wire thru a ferrit bead, this wire soldered
on the plate connection very close to the tube.
I you are posting schematics, could you post the whole schematics please ?
Last edited by peterh on Tue Mar 31, 2020 2:52 am; edited 1 time in total (Reason for editing : spelling)
peterh wrote:Arc-ing is a symptom of something really bad.
Thank you peterh for your response. I am including an image of the entire schematic with the screen stoppers drawn in. They are 100ohm resistors.
I am also including an image of the underside of my board so you can see the resistors in place and so you can tell me if they are close enough. I used metal film resistors because I read elsewhere it was ok, but I am willing to swap them out for carbon comps if need be.
Please understand, V5 is the only position that is having this problem. I have owned the amp since 1992. It gave me several years of trouble free service before tubes wore out. At the time I replaced them one at a time with the cheapest el34 I could buy at the guitar shop. At that point the bias resistors began blowing regularly, and shortly after an unknown resistor blew and I lost the right channel and I pulled the amp from service.
Last year, I rebuilt the amp, replacing every resistor and capacitor. After several dozen hours of service and many on-off cycles, V5 arced and red-plated. Then I replaced the original tube sockets and added the screen resistors. I replaced the tube with a matched one. While V5 no longer red-plates, it is still arcing, it has done it twice since the first time for a total of 3 times. Each time I have replaced the tube with a new matched one.
Which grid are you speaking of adding 1k resistors? The suppressor grid, pin 1?
- Post n°6
peterh wrote:Looking at the schematics , screen stoppers are missing, maybe the grid stoppers are too far from
Also, is 1/4 watt ok for both the 100 and 1k resistors?
- Post n°7
1/4w is ok, carbon comp is recomendedMechEngVic wrote:peterh wrote:Looking at the schematics , screen stoppers are missing, maybe the grid stoppers are too far from
The grid stopper is a resistor to the grid ( pin 5) It should be very close to the tube socket.
Looking at the picture it seems to be on the overside that the foild should be cut and
a grid stopper be mounted across the cut.
What tubes do you use right now, is this brand that has been arcing ?
- Post n°8
There already are 1k resistors between the coupling cap and the pin 5 control grid. That's in the schematic. The underside 100ohm resistors are the screen grid stoppers that I added. If I added a ferrite bead to the plate, would that go between the plate and the transformer?
I am currently using new production Mullard el34, but the same thing happened with Chinese Psvane el34 but always and only in the V5 position.
- Post n°9
The fact that one position is more prone to problems is an indication that the wiring is at fault.MechEngVic wrote:There already are 1k resistors between the coupling cap and the pin 5 control grid. That's in the schematic. The underside 100ohm resistors are the screen grid stoppers that I added. If I added a ferrite bead to the plate, would that go between the plate and the transformer?
The grid stopper might be at an inappropiate position. I suggest that you add another grid
stopper CLOSE to the tube socket. No need to remove the original , just add one
CLOSE to the socket.
Same with ferrite bead , mount CLOSE to the tube socket ( but wait until the effects of
stoppers is evaluated).
Tubes that has arc'ed is considered broken. Get new tubes !
Also read http://www.tronola.com/html/maximize_tube_life.html
- Post n°10
Ok, you've given me a fair amount of tasks to tackle. I will check the V5 wiring and add control grid stoppers close to the socket. Thanks again for your help.
- Post n°11
A comment about the ser II schematics
AN issue is the C15 C16 C25 C26 In the schematics they are spec.ed as 400Volt. That is not
enough !! AT power on the plate of the triode will get close to full B+ and at the same time
it will have the full bias (-) at it's other side.
I'd replace those with 630Volt caps.
And for stoppers; use carbon comp as they are purely resistive !
- Post n°12
I found that out when I first rebuilt the amp! I put in 400v caps and they blew within a few days. The caps in there now are 600v. I think you might have helped me with this issue about a year ago! Should I consider 630v? The tube is arcing at warn up when voltages are spiking and out of balance. I also noticed that the left channel (where V5 is located) takes twice as long to warm up as the right channel. Thanks for taking the time to look at the schematic more closely.
- Post n°13
630 is a "standard value". Theu also shold be reduced to between 0.1 and 0.22 uF in size , thisMechEngVic wrote:I found that out when I first rebuilt the amp! I put in 400v caps and they blew within a few days. The caps in there now are 600v. I think you might have helped me with this issue about a year ago! Should I consider 630v? The tube is arcing at warn up when voltages are spiking and out of balance. I also noticed that the left channel (where V5 is located) takes twice as long to warm up as the right channel. Thanks for taking the time to look at the schematic more closely.
makes it easier to find and also reduces leakage.
- Post n°14
Are you saying to reduce the coupling caps from 0.68uf to between 0.1- 0.22 uf? C15 C16 C25 C26? What about C13 & C23 of the driver tubes? They are also 0.68uf.
- Post n°15
Yes. They are needlessly large and may only aggrevate problems.MechEngVic wrote:Are you saying to reduce the coupling caps from 0.68uf to between 0.1- 0.22 uf? C15 C16 C25 C26? What about C13 & C23 of the driver tubes? They are also 0.68uf.
C13 and C23 is ok, they are decoupling caps.
- Post n°16
Interesting, would there be a change in sound quality or power output? And if you had to pick, 0.1uf or 0.22uf?
- Post n°17
No. In fact some improvements since sub-audial disturbances are prevented from saturatimgMechEngVic wrote:Interesting, would there be a change in sound quality or power output? And if you had to pick, 0.1uf or 0.22uf?
0.68uF and 270k load gives a 3db limit of 0.87hz
0.22 = 2.68hz
0.1 = 5.8hz
Original Dynaco ST-70 used 0.1uF
VTA-70 uses 0.22
Using tubes that needs smaller grid resistors ( R42,R43) such as 6550 where those should be
50k might need 0.68 uF as the 3db limit is 4.68hz
But EL 34 is perfectly happy with 270k
- Post n°18
Ok, I've been reading about this since you mentioned it and what you're saying is making sense. I think I'll settle in the middle and try some 0.22uf caps along with the rest of the fixes and see how it goes. You have taught me a lot since joined this forum. I appreciate it.
- Post n°19
peterh wrote:No. In fact some improvements since sub-audial disturbances are prevented from saturatimgMechEngVic wrote:Interesting, would there be a change in sound quality or power output? And if you had to pick, 0.1uf or 0.22uf?
0.22 = 2.68hz
0.1 = 5.8hz
VTA-70 uses 0.22
I found this calculator and I tried the values closest to a 3db limit of 2Hz (this website suggests 2Hz) and it gave me 0.22uf and 0.33uf. Is it better to be just above or just below this 20Hz Optimal low frequency response?
https://www.v-cap.com/coupling-capacitor-calculator.php
- Post n°20
MechEngVic wrote:peterh wrote:No. In fact some improvements since sub-audial disturbances are prevented from saturatimgMechEngVic wrote:Interesting, would there be a change in sound quality or power output? And if you had to pick, 0.1uf or 0.22uf?
0.22 = 2.68hz
0.1 = 5.8hz
VTA-70 uses 0.22
5 hz and 0.1 uF is what you need. It's also smallest and with least leakage.
» Bent / Splayed Power Tube Pins KT88 - Octal Tube Pin Straightener
» Another problem with my ST-70 build.......Rectifier tube flashed and now dead Right Rear Tube......any ideas?
» Glass piece inside output tube and tube placement
» Tube store tube number
» VTA 120 output tube red plated -- what do you check if you're using the AB board?
