    Be careful with KT-120 tubes in ST120
    Dolphins
    vta st120 - Be careful with KT-120 tubes in ST120 Empty Be careful with KT-120 tubes in ST120
    Post by Dolphins Mon Jul 22, 2024 11:25 pm
    I decided to give the Tung-sol KT 120's a try in my ST120. Well, that was mistakes 1 through 4. I turned all 4 bias pots counter-clockwise and installed the 120's and turned it on. I went to adjust the bias and the meter showed 550 v (not mV). Turning the bias pots did not do anything. I replaced the Sovtek SSR solid state rectifier, and re-installed my 6550 tubes. Now, the bias on all tubes are 10v, but I am still not able to adjust it. I should have just left well enough and not wasted $ on KT 120 tubes, plus the cost of amp repairs.
    Just curious if anyone has any idea what went wrong....
    avi.inc
    vta st120 - Be careful with KT-120 tubes in ST120 Empty kt-120 tubes
    Post by avi.inc Wed Sep 04, 2024 3:31 pm
    I have been running kt-120 in my st-120 hi-gain amp for many years no problem.
    Dolphins
    vta st120 - Be careful with KT-120 tubes in ST120 Empty Re: Be careful with KT-120 tubes in ST120
    Post by Dolphins Mon Oct 07, 2024 9:48 pm
    As it turns out, I had a defective KT-120. I installed a new quad, and the amp sounds wonderful. I would like to add that the protection resistor for each tube, worked as it was designed. Only had to repalce that resistor, install new tubes, and everything is fine.
      Current date/time is Tue Nov 26, 2024 3:23 am
