    tube rectifier diode mod
    Post by tubes4hifi on Mon Nov 07, 2011 2:55 pm
    this is a common topic and search, so it'll be easier to find now
    this mod should be done to all tube amps using tube rectifiers, to reduce the chance of damaging the tube rectifier
    pmit2188
    Re: tube rectifier diode mod
    Post by pmit2188 on Wed Nov 16, 2011 4:12 pm
    I would like to make this mod. Can anyone tell me if the 1N4005 diode will work. It is the only one I can get at a local store. (Radio Shack)
    anbitet66
    Post by anbitet66 on Wed Nov 16, 2011 6:57 pm
    The 1N4005 has a reverse breakdown voltage of 600 volts as compared to a 1N4007's 1000 volt rating. It will work, but I'm not sure if the diode's breakdown voltage needs to be higher in order for it not to be damaged.
    With it in series with a 5AR4 it probably doesn't matter, but I'd wait for another opinion. My guess is it would work just fine.
    Tony
    Post by Bob Latino on Thu Nov 17, 2011 6:22 am
    Those diodes will look at about 360 VAC. Either the 1N4007 or the 1N4005 should work fine .. Since the 1N4007 is 1000 volt rated, I would probably use the 1N4007 ...
    pmit2188
    Post by pmit2188 on Thu Nov 17, 2011 5:34 pm
    Thanks Tony and Bob for the help. Tim.
    heyraz
    More Diodes
    Post by heyraz on Fri Nov 18, 2011 8:47 am
    I saw this on DiyAudio: "Dynamutt, The ST-70 that should have been". Two MUR4100 are placed in series (total 4). I'm not sure why they did it this way.
    http://geek.scorpiorising.ca/contrib/Geek/ST-70-P10CVD_power.gif
    http://www.diyaudio.com/forums/blogs/geek/140-dynamutt-st-70-should-have-been.html
    Post by Bob Latino on Fri Nov 18, 2011 9:57 am
    When you put two diodes in series you get more reverse current blockage than using just one diode. That's why two diodes are used on each leg of the power transformer secondary.
    On another note ..
    The power schematic at the link you provide for the "Dynamutt" at > Dynamutt ST-70 power supply is IMHO not really any better than the stock power supply for the original ST-70. That power supply on the Dynamutt is a 47, 23.5, 23.5, 23.5 uF @ 700 VDC. The original ST-70 had a 30, 20, 20, 20 uF @ 525 VDC. Since the ST-70 has a B+ of 430 volts or so, the 525 VDC quad cap rating was fine for the original ST-70. The Dynamutt does not really improve on the amount of DC power storage - just voltage handling. Having just a SINGLE 23.5 uF quad cap section to run TWO output transformers is OK up to 20 - 25 watts and then the power supply "craps out". The Dynamutt system also has no "on board" power supply for their driver circuit like the VTA driver circuit. The 47, 23.5, 23.5, 23.5 (117.5 total) runs the whole amp and is about as undersized as the original Dynaco ST-70 amp which had just 90 uF total DC storage ..
    On the other hand, the VTA ST-70 amp KIT has a 170 uF quad cap @ 550 volts with two sections wired together to power the two output transformers (100 uF total and about 4.5 times the Dynamutt's 23.5 uF total for the output transformers). The VTA driver circuit also has another 294 uF for just the driver board. This is one of the main reasons (a large and more modern power supply) that the VTA ST-70 amp KIT, although rated at "35 watts per channel", is actually a 45 watt per channel amp. See independent test link below.
    Independent test of the VTA ST-70 amp KIT
    The VTA ST-120 adds another 165 uF or DC storage for just the two output transformers (265 uF total) and has the same 294 uF on the driver circuit as the VTA ST-70. The VTA ST-120, although rated at 60 WPC, is also conservatively rated, and will do > 70 WPC over most of the audio band.
    heyraz
    Post by heyraz on Fri Nov 18, 2011 11:21 am
    Agreed. I was only wondering about the diodes in series and why the Dynamutt guy may have thought it was benificial. I suppose it is a "backup for the backup" redundant design. Thanks again for all of your help. Rich
    Post by GP49 on Fri Nov 18, 2011 11:27 am
    While the 1N4005 would work as protection devices for the rectifier tube, for safety reasons I'd want to go with a diode having the voltage rating they would require if they were doing the rectification job all by themselves. If the rectifier tube were to fail shorted, the 360AC RMS voltage, recalculated to peak voltage, could go far over the 600PIV of the 1N4005, which could then itself fail shorted and throw a huge current on the power transformer until something blew (hopefully the line fuse).
    Silicon rectifiers used in a full-wave, two-phase power supply should have a PIV rating of 2 times 1.4 times the RMS voltage being delivered by the transformer. With the Dynaco Stereo 70 transformer at 360-0-360Vrms the diodes should be rated at 2 x 1.4 x 360 = 1008V PIV. This is very slightly more than the 1000V rating of the 1N4007 but with tolerances on the diodes' PIV generally all on the positive side, the 1N4007 would probably survive.
    I appreciate that parts are not as available as they once were, but being conservative in design matters, I would suggest that instead of settling for what Radio Shack has, you look into other vendors that could supply the 1N4007.
    pmit2188
    Post by pmit2188 on Sat Nov 19, 2011 8:42 am
    I failed to tell you that my amp is the SP-120 if that makes a difference. Well, after making the mod with the 1n4005 diodes it was put to the test with one of those quick power outages when the power goes out and then comes right back on again during a wind storm. The rectifier tube is still working. Yes!!
    mantha3
    Post by mantha3 on Thu Jan 05, 2012 4:36 pm
    I put some time (too much time) into researching this mod after I lost a nice NOS Sylvania big bottle GZ34. I think the real fix to the lost GZ34 was me not turning my ST120 amp up to full blast... Anyhoo...
    I found some conversations about what diode to use for this Mod. I ended up going with a UF4007. the UF4007 is basically the same as a 1N4007 having 1A / 1,000 volt rating but a more modern Ultrafast recovery version diode. One post spoke of the UF4007 potentially limiting the possible “switching” you could hear. This “switching” got shot down by a few who talked about all the capacitance that would buffer this out. I also saw some conversations about the need to go with the full 1,000 volt and I read some detail about why the 1,000 volt diode is needed. I wish I could find it. I'm not as tec savy to have this in my head. I’d go safe and run the 1,000 volt and error on the side of over spec... So go UF4007 or 1N4007
    1N4007 is a $.09 each (http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/1N4007/?qs=sGAEpiMZZMuQUXCJI7Y4lvWy%252b1U8RtCq)
    UF4007 is $.49 each (http://search.digikey.com/us/en/products/UF4007/UF4007CT-ND/965732)
    You may have a harder time finding the 1N4007 as the UF4007 is sort of the current diode for the application I think… Either way the mod should cost 20 cents or you can go Deluxe for the full 1 buck! I thought I’d live it up and go a buck! … Oh, plus shipping.
    I use www.digikey.com because they are in Minnesota where I’m at. So I support em.
    Don’t use something else.. wait the 3 days to have the UF4007 or 1N4007 come in the mail… any pay the couple bucks to have them come. We all have audio problems and probably pay too much for this hobby… 3 bucks is not worth a cut corner! Laughing
    Cheers (insert beer drinking smily here)
    www.mouser.com
    www.digikey.com
    Feistygoat
    Post by Feistygoat on Mon Feb 13, 2012 12:18 am
    Bummer - I want to do this mod, I only show one red lead going to my rectifier socket. I have a van Alstine modded ST - 70, so assume changes may have been made. In the diagram at the beginning, it says to move the red leads to pins 5 and 7. That being the case, what two pins are the power leads originally on? Is it 4 and 6 where the diodes (after the mod) jump to?
    I apologize for my ignorance. I am fairly new to this, but trying to learn fast. Any help is much appreciated.
    burnedfingers
    Post by burnedfingers on Mon Feb 13, 2012 5:47 am
    Your transformers two red power leads originally went to pins 4 and 6 and since the pins 5 and 7 are not used it makes sense to use them. Pull the wires off pins 4 and 6. Install a diode band side to pin 4 and the other end to pin 5 install one of the power wires to pin 5. Install the second diode band end to pin 6 and other end to pin 7 install other power wire to pin 7. If you cannot find your two red power wires on the 5AR4's socket then trace the wires from the transformer and see where they go.
    There is absolutely no difference sonically between a standard 1N4007 and the fast recovery. YOU WILL NOT HEAR A DIFFERENCE!!!
    Feistygoat
    Post by Feistygoat on Mon Feb 13, 2012 9:49 am
    Thanks for the help. I knew there wouldn't be any difference sonically, I just want to preserve my rectifier as long as possible
    heyraz
    Post by heyraz on Mon Feb 13, 2012 1:32 pm
    Here's how I did it. I mounted a 2 tab ungrounded terminal strip on one of V1's mounting screws and moved the red transformer wires to that. Follow the diodes in the picture to see the rest. Note-Try to give the diodes breathing room because they get hot.
      Current date/time is Thu May 23, 2013 8:09 pm
