    New PC board caps...polarity?
    wildiowa
    New PC board caps...polarity? Empty New PC board caps...polarity?
    Post by wildiowa Mon Mar 26, 2012 6:05 pm
    Just got new Sprague Orange Drop caps for the board on my ST70, Sprague 716P series from Antique Elec. Supply...four .1mfd 600 v and two .047 400v. There is no visible polarity stamped on these, I thought for certain there would be a "+" or "-" or some indication which lead is which, but nothing! Or, is there no difference in what direction I put them in? The old Pyramid Imps seem to have a stripe on one end that might indicate polarity....stupid question, but what the heck? I thought these had to be in the correct plus-minus configuration when installed. Any help appreciated. Thx. IA.
    New PC board caps...polarity? Empty Re: New PC board caps...polarity?
    Post by Roy Mottram Mon Mar 26, 2012 6:10 pm
    only electrolytic caps are polarized, the 716P are not and can go either way
    wildiowa
    Post by wildiowa Mon Mar 26, 2012 6:18 pm
    Yay! There is a God! Looking forward to installing new stuff tonight...also got the quad cap and bias caps from Dynakitparts....will be eager to fire the new rig up. Thanks.
    IA
    anbitet66
    anbitet66
    Post by anbitet66 Mon Mar 26, 2012 10:11 pm
    There is no polarity on an orange drop. But if there is a line on the body near one of the wires that would be the connection to the outer foil. That would be important if the capacitor is connected to ground (as in a bypass application) to minimize hum pick up. If the capacitor is used for coupling, then it doesn't matter which way you connect it.
      Current date/time is Wed May 08, 2024 3:49 pm
