    Issue with sylvania 6ca7
    bktheking
    Issue with sylvania 6ca7 Empty Issue with sylvania 6ca7
    Post by bktheking Wed Jul 25, 2012 10:38 am
    in my amp, with v11 VTA board running the SDS cap board, I have a 6ca7 - sylvania that biases up perfectly then after a minute runs away. It tests at 78 percent in my tube tester without issue. I've read a few sites that talked about these tubes being superior to anything new yet so many of them have this thermal runaway issue and it's more predominant in St-70's. Is there anything that can be done like changing out a grid resistor or is this tube simply destined for the trash? My jj's operate flawlessly.
    Many thanks
    Issue with sylvania 6ca7 Empty Re: Issue with sylvania 6ca7
    Post by Bob Latino Wed Jul 25, 2012 10:59 am
    If that Sylvania 6CA7 has runaway bias no matter what tube socket you place the tube in, then the tube is bad. If the tube is new, I would send it back to the vendor and request a replacement.
    bktheking
    Post by bktheking Wed Jul 25, 2012 11:06 am
    Any socket it goes nuts, it came in a box of tubes I bought at a hamfest, probably why it was in the box.
    Post by Roy Mottram Wed Jul 25, 2012 12:50 pm
    try changing R29 - R32 to 150K rather than 220K or 270K as was original, that has helped me in the past with tubes with this type of problem
    bktheking
    Post by bktheking Tue Jul 31, 2012 9:36 am
    Without changing anything- I got another sylvania 6ca7 and put it in with the tube that was causing the issue. Last night I biased it up and it held stable for 15 minutes.
    Strange.
      Current date/time is Thu May 02, 2024 9:52 am
