    Mk II ... Mk III
    hup_d_dup
    Mk II ... Mk III Empty Mk II ... Mk III
    Post by hup_d_dup Thu Jun 11, 2009 4:13 pm
    Is it feasible to upgrade a MkII to a MkIII? What would it take to do this?
    The reason I'm asking is that I may have an opportunity to purchase a pair of MkIIs. They would be used in a bi-amped system with MkIIIs. It would be very important for the amps to be closely matched.
    Mk II ... Mk III Empty Re: Mk II ... Mk III
    Post by GP49 Thu Jun 11, 2009 4:50 pm
    It is not difficult. I've done it for customers who asked.
    You need to replace the 5U4 rectifier tube with a 5AR4/GZ34; and the 50Ω 10W resistor in the B+ supply with a filter choke. The one sold by Dynakit Parts for the Stereo 70 is exactly correct and you will need to drill the chassis to mount it.
    Then you would replace the EL34 output tubes with 6550 tubes, and reset the bias. Nominal idle current for the EL34 in a Mk II is 65mA per tube; for the Mark III with 6550, it's 70mA per tube. The specified 1.56 Biaset voltage will no longer apply; you would set the Biaset measurement to 1.68 volts instead. If you want to get a nominal 1.56 Biaset voltage on a Mark II with 6550s, you would replace the 12Ω cathode resistor with an 11.2Ω resistor.
    Nowadays many users set the output stage bias lower than the original Dynaco specs, since modern tubes appear to be less durable than the old ones. If you do, you'll have to calculate what the Biaset voltage measurement will be for your desired bias current.
    You still will not have a 4Ω tap on the output transformer, unless you have one of the very few Mark II that was special-ordered with 4Ω and 8Ω taps instead of 8Ω and 16Ω. Some claim to have seen Mark II with Mark III output transformer, and the 4Ω wire hanging loose and taped off. This is conceivable but I've never seen it myself.
    Post by Bob Latino Thu Jun 11, 2009 6:19 pm
    Hup,
    Although a Mark II made be made into Mark III as GP49 has mentioned you probably won't have to do it. The Mark II is rated at 50 watts and the Mark III at 60 watts. The increase in power of 10 watts from 50 to 60 is only about .78 dB. If you run the Mark III's on your woofers and the Mark II's on your tweeters the difference of .78 dB may not be noticeable. Also, the Mark II at rated specs needs a slightly less input level (1.5 volts) than the Mark III (1.6 volts) to reach full output. At the same input voltage level the two amps will probably track even closer than the .78 dB mentioned.
    What I would do try the two sets of amps as is and if you DO notice a slight difference in gain between the two amps then I would make a slight alteration to the feedback resistor on either (or both) amps to alter the gain of the amp. Lets say that you need slight gain increase on the Mark II. The Mark II has a 1000 ohm feedback resistor next to eyelet 7 on the driver board. Try changing that to 1200 ohms or 1500 ohms. Going to a higher feedback resistor decreases feedback and increases gain. Now some might say that any alteration of the feedback resistor will change the "character" of the amp. Having done this a number of times, SUBTLE changes in the feedback of an amp IMHO don't really alter the character of the amp that much. The 1000 ohm feedback resistor on a Mark II is right next to eyelet #7. You can see the feedback line coming from lug #3 (16 ohm) on the output terminal strip going to eyelet #7.
    hup_d_dup
    Post by hup_d_dup Fri Jun 12, 2009 8:46 am
    Thank you. Those were both great answers, just the information I was looking for. Bob, I'm not as much concerned about the gain as I am about the "character," as you put it. Here's why; I'm using Vandersteens which are ideally set up for bi-amplification, but the Vandersteen manual advises caution when considering this. "Even if the levels of the amplifiers are matched for one volume level, the amplifiers will still exhibit different dynamic characteristics, different imaging characteristics, different degrees of detail and instrument texture and different tonal balances. With the crossover between the woofer and midrange occuring in a range where the ear is very sensitive to any sonic changes, these differences will create considerable confusion through the important midrange." The differences between the MkII and MkIII may be so slight that they are not significant, but the Vandersteen advisory has at least made me consider if adding the MkIIs could be a step down rather than a step up. For this reason I think I would be more confident in upgrading the MkIIs to MkIIIs.
    Last edited by hup_d_dup on Fri Jun 12, 2009 8:50 am; edited 1 time in total (Reason for editing : clarification)
    Post by GP49 Fri Jun 12, 2009 11:39 am
    I think it would be sufficient, actually, to change the output tubes and rebias. All else is power supply modification. and if the Mark II are the tweeter amps, the demands will not be as great on them.
    There is a difference in sound between EL34 and 6550 which would be greater than the ten-watt difference in output power. In fact, while you are swapping tubes (don't forget readjusting the bias each time), you may find you prefer the sound of the EL34 over the 6550, using them in the Mark III (instructions on setting the bias for EL34s in Mark III are in the instruction manual). For all the fuss people make about how one brand of EL34 sounds different from another (and they do!), the different tube types are far MORE different; and since the two types are effectively interchangeable with the appropriate bias adjustments, I'd think the time taken to do listening tests would be worth it.
    There is no problem with doing this; the EL34 handles the higher plate voltage of the Mark III just fine. In fact, original Mullard EL34s are rated at 800 volts on the plates, far above what a 6550 can handle.
      Current date/time is Fri Apr 26, 2024 11:36 am
