    How would you Modify a MK III to use EL156 tube ?
    Tazsmonn
    Tazsmonn
    How would you Modify a MK III to use EL156 tube  ? Empty How would you Modify a MK III to use EL156 tube ?
    Post by Tazsmonn Mon Jun 22, 2009 11:26 pm
    Could you just set the bias and let go?
    I have checked the heater current need 1.9A each & believe there would be no problem with the source being able to put out 5A.
    Am going to try it this weekend.
    Will report latter.
    How would you Modify a MK III to use EL156 tube  ? Empty Re: How would you Modify a MK III to use EL156 tube ?
    Post by GP49 Tue Jun 23, 2009 12:50 am
    Tazsmonn wrote:Could you just set the bias and let go?
    Will report latter.
    You mean, other than the EL156 needing a ten-pin socket?
    Spec sheet:
    http://www.mif.pg.gda.pl/homepages/frank/sheets/118/e/EL156.pdf
    I don't know for sure but would suspect that this tube will require more negative voltage on the grid to bias up properly.
    Tazsmonn
    Tazsmonn
    How would you Modify a MK III to use EL156 tube  ? Empty 8 pin EL 156
    Post by Tazsmonn Tue Jun 23, 2009 11:10 am
    Antique Electronic Supply sells an 8 pin style EL 156, this is what I have.
    Post by GP49 Tue Jun 23, 2009 4:48 pm
    Ah, I see that the Chinese put an octal base on it!
    The screen grid voltage in Class AB seems a bit low at 350 volts.
    Specs at:
    http://ozvalveamps.elands.com/el156generic.htm
      Current date/time is Fri Apr 26, 2024 9:38 am
