+2
ttocs
98indypacer
6 posters
    Anyone Modify M125 for Individual Bias?
    98indypacer
    Anyone Modify M125 for Individual Bias? Empty Anyone Modify M125 for Individual Bias?
    Post by 98indypacer Tue Feb 15, 2022 10:37 am
    I understand if you use a matched set of output tubes in the M125 the current bias setup should be fine but what happens if you have a tube failure and you have to replace one tube. I was wondering if anyone has modified their M125 for individual bias. If so, do you have a schematic and wiring diagram?
    Thanks, Ed
    ttocs
    ttocs
    Anyone Modify M125 for Individual Bias? Empty Re: Anyone Modify M125 for Individual Bias?
    Post by ttocs Tue Feb 15, 2022 11:53 am
    I haven't done what you're requesting. However, if replacing just one tube, disregarding for the moment the amount of hours on the remaining tubes, you can supply the tube vendor with the test measurements from the original tube so they can attempt to choose a tube that matches as close as possible. There should've been test measurements on the box the original tube came in, like this:
    Anyone Modify M125 for Individual Bias? Gold-l10
    I'd be interested to see how the wiring would look for individual bias as well.
    rebellovw
    Post by rebellovw Wed Feb 16, 2022 12:15 am
    I've given up completely on matched quads - I just use four good tubes and set the bias accordingly. If I lose I tube - I just replace it and reset the bias. Been doing it this way a long time.
    Also when you use only two output tubes - then you can bias each tube - in fact - I've had different tube brands - sounded just fine - ex gold lion mixed with Sovtek (both KT88s)
    Rec
    Post by Rec Wed Feb 16, 2022 10:15 am
    Yea with 8 tubes it is almost impossible to keep a matched quad and a fat wallet. One will invariably blow first and need to be replaced, for whatever reason. Honestly, if you pull tubes to work on the amp or whatever reason, things can get mixed up!
    Im with rebellovw here, although I dont mix tube vendors and a "try" to get close with the replacement. Just re bias. Never an issue.
    The unit ships with a schematic, after a quick look, Im guessing it's more than just adding 2 pots per side. I'd guess that for the M125 this would add more than just two bias pots, and more opportunity to be concerned about "mismatch" (eg probably a 1/2 12AU7/coupling cap per tube). All this happens on the driver board. The 120 has individual tube bias.  *Maybe* you can just use a 120 driver board with a few resistor tweaks to hit M125 B+ voltages and run the input stage in parallel?
    I wouldn't overthink it. Just watch your bias every. As I type I am enjoying my (biased) M125 and I have no clue as to whether any tube matches.
    Juice is not worth the squeeze in my opinion, and would likely introduce complexity in the preamp stage that could negatively affect the sound.
    LeGrace
    LeGrace
    Post by LeGrace Wed Feb 16, 2022 12:35 pm
    Adding auto biasing boards will convert the amps to individual bias control. Pretested modern tubes may start out matched, but I dont believe they stay that way for long. In first 2 years I accumulated enough orphan tubes I figure to see me through next decade, now that I can use them up. Or maybe even longer, enjoying significantly increased tube life now as well.
    mijohn and 98indypacer like this post
    98indypacer
    Post by 98indypacer Wed Feb 16, 2022 11:17 pm
    Rec wrote:
    …All this happens on the driver board…
    After looking at it a little more closely I realized I would probably have to modify the driver board or install another board to move the existing bias pots and add two more. Could be done but would be a pain to do. I just rebuilt a Sansui 1000A that had a single bias pot and made a new board to convert it to 4 bias pots.
    98indypacer
    Post by 98indypacer Wed Feb 16, 2022 11:20 pm
    LeGrace wrote:Adding auto biasing boards will convert the amps to individual bias control. Pretested modern tubes may start out matched, but I dont believe they stay that way for long. In first 2 years I accumulated enough orphan tubes I figure to see me through next decade, now that I can use them up. Or maybe even longer, enjoying significantly increased tube life now as well.
    I’m new to this forum but looking over the history it seems like the AB mod has fallen out of favor.
    LeGrace
    LeGrace
    Post by LeGrace Thu Feb 17, 2022 6:39 am
    I can only share my personal experience which has been stellar since installing them about 2.5 years ago.  Important to note I installed newer rev 2 boards, not the original problematic rev 1.
    98indypacer
    Post by 98indypacer Thu Feb 17, 2022 10:52 am
    Are you running the AB board with a tube rectifier or using solid state?
    JohnC
    JohnC
    Anyone Modify M125 for Individual Bias? Empty Auto biasing board
    Post by JohnC Thu Feb 17, 2022 11:27 am
    I have had auto biasing boards in my VTA-120 and M-125s for nearly 2 years and they have been very reliable. I run tube rectifiers in both systems.
    I am of the understanding that constant adjustment of the pot on the AB board is detrimental to it's survival.
    Both systems are on bucking transformers at 115V. Before the auto biasing boards, I was amazed at the fluctuations in bias voltage due to inconsistant service voltage from the local utility.
    Also, this is my experience with the AB boards.
    LeGrace likes this post
    LeGrace
    LeGrace
    Post by LeGrace Thu Feb 17, 2022 12:50 pm
    Tube rectifier type GZ37. My experience mirrors that of @JohnC, pre AB bias settings required frequent attention. Post AB zero attention. Oh I'll double check once in awhile but the readings never deviate from original setup.
    ttocs
    ttocs
    Post by ttocs Thu Feb 17, 2022 2:39 pm
    My bias never needs adjustment. But I use a Variac so the voltage at startup is always the same. Months go by with no need of adjustment.
      Current date/time is Sun Apr 28, 2024 12:42 am
