+3
7 posters
    New Member
    New Member Empty New Member
    Post by Maintarget Sun Feb 17, 2013 7:46 pm
    After much on line research I have narrowed my choice of entry into the world of dyi tube amps to the ST-120 kit.
    The quality of the kit parts, options and instruction appear to be first rate thanks to Roy and Bob's commitment to quality at a fair price.
    My only reservation is cosmetic in nature I just don't care for the location of the inputs, on/off switch and the sockets to set bias, my plan would be to build a larger custom enclosure of aluminum and relocate the on/off switch to the front and the inputs to the rear of the amp and use the M-125 style of pin sockets for biasing located on top near the driver board.
    I would also clean up the top of the enclosure by mounting the driver board on stand offs so only the tubes are protruding out the top, the basic layout of all other components would closely follow the original layout.
    My question is can this be done without degrading sound quality with careful wire routing/shielding?
    Any suggestions or comments would be greatly appreciated.
    New Member Empty Re: New Member
    Post by Bob Latino Sun Feb 17, 2013 8:36 pm
    We have had a few people build VTA amp kits on a custom chassis that they designed themselves. About the only two things you have to worry about are ..
    1. If you are going to place the power switch on the FRONT of the amp, twist the AC wiring from the power transformer and run it around one side of the chassis. IOW keep the AC wiring away from the driver circuit.
    2. If you are going to place the input jacks on the rear of the amp either use shielded cable to run the wires to the driver board input eyelets near the front of the amp OR twist both pairs of input wires together and run them around the side of the chassis that is opposite of your AC power wires as mentioned in #1 above.
    Post by Maintarget Mon Feb 18, 2013 2:08 pm
    Thank you Bob, Ill be sending you a e mail with my order soon.
    Post by Roy Mottram Mon Feb 18, 2013 4:11 pm
    have built dozens of amps in that fashion, see 3 examples of photos below:
    New Member Gil1
    New Member ST80a
    New Member ST120b
    denny9167
    denny9167
    Post by denny9167 Mon Feb 18, 2013 4:21 pm
    I have below an example of a pair of Mark IV's that
    I built using my own design. I'm thinking on building a pair of Mark IIi's
    Using the same layout. Which is good all the way around
    I'm the same layout would work for a 120.
    New Member 96bb44dd5421b96296bd85d6dff0d1d3_zps278050f2
    Post by Maintarget Mon Feb 18, 2013 4:37 pm
    Beautiful work gentelmen!
    These examples are more in line with my personal taste and the look I would like my amp to have, something about the combination of wood, aluminum and color/paint when done right that is pleasing to the eye.
    I have sent my request to Bob now the hard part tempering my excitment until I actual recieve my kit....
    denny9167
    denny9167
    Post by denny9167 Mon Feb 18, 2013 6:38 pm
    I am also using Sketchup 8 and Povray to help me in the design of my amps. Would love to help any way I am able to.
    [img]New Member Markiv_zpse980b33a[/img]
    jjones3318
    jjones3318
    Post by jjones3318 Mon Feb 18, 2013 10:33 pm
    Here are a pair of custom M125's.
    New Member P1060610
    denny9167
    denny9167
    Post by denny9167 Tue Feb 19, 2013 7:52 am
    jjones3318 wrote:Here are a pair of custom M125's.
    New Member P1060610
    Nice!!
    Sprags
    Post by Sprags Wed Mar 13, 2013 1:27 am
    Those are nice looking M125s.
    terry37932
    terry37932
    Post by terry37932 Thu Mar 14, 2013 12:43 pm
    [quote="denny9167"]
    New Member P1060610
    Nice!![/]
    I Think I'm in love!
      Current date/time is Fri Apr 26, 2024 12:30 pm
