    Mark 3 driver boards
    toolGURU
    Mark 3 driver boards Empty Mark 3 driver boards
    Post by toolGURU Wed Dec 10, 2008 2:25 pm
    Any recommendations for driver boards? Options I've seen:
    1. Original replacement design
    2. Curcio audio upgrade
    3. Triode electronics upgrade
    4. Poseidon driver board (diytube.com)
    I'm not interested in preserving the original sound of the amp. I'd
    like to correct all the know issues to make this amp sound the best
    it can.
    DynakitParts
    DynakitParts
    Mark 3 driver boards Empty MK III Driver Boards
    Post by DynakitParts Wed Dec 10, 2008 2:48 pm
    Hi ToolGuru,
    You should include Roy Mottram's
    upgrade MK III driver board to your short list.
    Take a look at this at: www.tubes4hifi.com
    Kevin @ Dynakit
    Mark 3 driver boards Empty Tubes4hifi VTA driver board for the Dynaco Mark III - photo
    Post by Bob Latino Wed Dec 10, 2008 6:40 pm
    Yes, If you are going to go with an upgrade board on your Mark III instead of a stock type board then the Tubes4hifi VTA upgrade driver board should also be considered. Here are two reasons why ... Laughing
    1. Most upgrade driver boards do not allow individual biasing of each tube as the VTA does. Those are the two small blue potentiometers that you see on the top. Most upgrade driver boards still rely on the original bias system which was for each PAIR of tubes. With this driver board you don't absolutely need a matched pair of output tubes.
    2. Most other upgrade driver boards do not have an "on board" power supply. Those are the two black capacitors on the back edge in the photo. If a driver board doesn't have an on board high voltage power supply it has to "steal" power from the quad cap, underchassis power supply or whatever is the main power supply in the amp.
    Mark 3 driver boards VTAmarkIIIdriverboards
    Mark 3 driver boards Empty Re: Mark 3 driver boards
      Current date/time is Sat Apr 27, 2024 9:56 am
