    DAC for a CD player
    DAC for a CD player Empty DAC for a CD player
    Post by Dave_in_Va Tue Feb 18, 2014 6:09 pm
    I have a VTA ST 70 and the VTA SP/PH10 pre-amp. I mainly use this for vinyl but I do have a load of CDs. My CD player is a plain vanilla Onkyo C 7030. Would I gain much in sound quality by going into a DAC (bypassing the internal DAC) and then into my SP 10?
    The two DACs I've been looking at are the Cambridge DacMagic 100 ($100 off at A. A.) or the Music Fidelity V90-DAC. These are at the outer limits of my budget ($299).
    Worth it?
    Associated question....Is there any advantage to coaxial out over optical (toslink) out on the CD player?
    Thanks in advance for your advice.
    Dave
    daveshel
    daveshel
    DAC for a CD player Empty Re: DAC for a CD player
    Post by daveshel Tue Feb 18, 2014 6:29 pm
    Dave
    I'm thinking of giving the V90-DAC a try but now that you mention it the Cambridge looks interesting as well. I wonder under what circumstances you would use the ground lift.
    Post by sKiZo Tue Feb 18, 2014 6:35 pm
    Ground lift?
    Sounds like something you'd normally run into with pro equipment using XLR or unbalanced connections. Some setups need the second ground (pin#3?) "lifted" or open to work properly. Mostly hummmmmm issues ...
    In that case, there's either a switch to open that connection, or you need to get an adapter or just desolder the connector in the cable itself.
    Or not ... ground lift?
    Post by Dave_in_Va Wed Mar 05, 2014 9:30 pm
    In case anyone is curious, I ended up using the coax-digital out of my Onkyo CD player into the Musical Fidelity V-DAC II, out of the DAC into the acc. in of the SP-10. There was a major improvement. Now I can really enjoy my CDs as well as my LPs.
    I also ran a 15' toslink out of my TV into the V-DAC and the audio from my Roku and DVD players is really improved also.
    Lot's of improvement today for about $25 in cables.
    frank
    frank
    Post by frank Wed Mar 05, 2014 9:47 pm
    OK, I came late to this party. I would have answered: it depends. It depends on the quality of the DAC in your CD player. Looks like you got it worked out. Good job!
      Current date/time is Fri Apr 26, 2024 7:49 pm
