    GEC Ediswan cv345/12e1 power tube.... KT-88 eqivalent?
    scottlowe
    GEC Ediswan cv345/12e1  power tube.... KT-88  eqivalent? Empty GEC Ediswan cv345/12e1 power tube.... KT-88 eqivalent?
    Post by scottlowe Wed Jun 25, 2014 1:39 pm
    Hi another question? Is this a drop in replacement for the kt-88? can I just put it in my st-120? thank you,Scott Neutral
    GEC Ediswan cv345/12e1  power tube.... KT-88  eqivalent? Empty Re: GEC Ediswan cv345/12e1 power tube.... KT-88 eqivalent?
    Post by stewdan Wed Jun 25, 2014 3:52 pm
    Hi Scott --- take look at the following links:
    http://www.duncanamps.com/tdsl/show.php?des=CV345 and
    http://www.r-type.org/exhib/aai0167.htm
    In the picture of the CV345 on the aai0167.htm page, there is a metal connector on the top of the tube which requires some sort of electrical signal.
    The 6550/kt88/kt100/kt120 tubes do not have the topside connection.
    So, the CV345 is not a drop in replacement for a VTA ST120 Amplifier.  Also the other tube you mentioned, the 12e1 which is something like the CV345 is also not a kt88 replacement tube.
    Hope this helps,
    Stew
    Post by stewdan Wed Jun 25, 2014 3:55 pm
    Scott -- also, on the Duncanamps page for the CV345, there is no mention of the KT88, only the 12e1.
    Stew
    Post by sKiZo Wed Jun 25, 2014 4:59 pm
    Just for yuks ...
    The KT88 anode is pin #3. That pin is "no connection" on the CV345.
    So ...
    Run a tail and anode cap from pin #3 on the KT120 socket to make the connection on the CV345?
    Certainly be a conversation piece if you could get it to work ...
      Current date/time is Fri Apr 26, 2024 8:58 am
