+3
bluemeanies
7 posters
    Tube Storage
    bluemeanies
    bluemeanies
    Tube Storage Empty Tube Storage
    Post by bluemeanies Thu Mar 10, 2016 10:05 am
    I have about a dozen to 15 extra tubes that are in there individual boxes and then on top of that in another bigger box.
    Does anyone know where there are storage boxes for vacuum tubes. One that can store those big output tubes.
    I seen some on the web but nothing that I liked...from cardboard to cheap plastic. Matter of fact the heavy duty cardboard looked better than the plastic.
    There was a nice container on TUBE DEPOT that held 18-20tubes with foam cushioning @$54.95 plus shipping but I wanted something a bit cheaper.
    Tube Storage Empty Re: Tube Storage
    Post by arledgsc Thu Mar 10, 2016 10:41 am
    I've always wanted a "vacuum tube caddy". You can search Ebay as there are several examples that may fit your needs or give you ideas. If you can find the right foam that is removable in sections you could probably roll your own. I think Skizo here on the forum showed us a while back some pictures of his solution with removable, sectioned foam. But I need to do something as well as my tube collection is just thrown in a box.
    Post by peterh Thu Mar 10, 2016 10:47 am
    bluemeanies wrote:I have about a dozen to 15 extra tubes that are in there individual boxes and then on top of that in another bigger box.
    Anal as I am at times this bothers me.
    Any box or bag will do , and storage in dry hydrogen-free atmosphere.
    A note on the outside of the box/bag about it's contents will spare the tubes
    from repeated searches.
    Post by deepee99 Thu Mar 10, 2016 2:07 pm
    I use those large Tupperware-like tubs (L12"xW6"xD4") with sealing lids and segregate the tube-types by box. They come on sale at our local hardware store for a buck or two every now and then and are stackable.
    You can put about a dozen boxed KT-88/6550 sized tubes in just one of them and they are just transparent enough you can see what type tubes you've got in each box. I don't know if the sealed lids keep out hydrogen, though. Suppose a little bag of desiccant in each would be helpful to keep airborne moisture to a minimum.
    Post by peterh Thu Mar 10, 2016 3:27 pm
    deepee99 wrote:I use those large Tupperware-like tubs (L12"xW6"xD4") with sealing lids and segregate the tube-types by box. They come on sale at our local hardware store for a buck or two every now and then and are stackable.
    Nope, plastic boxed does not keep hydrogen out, has nothing to do with lids.
    Make sure no hydrogen in the room ( battery charging for instance ). Hydriogen
    might, when exposed for longer periods, creep into tubes. Just like helium but that
    is rare. And we are talking about years of exposure ...
    We were talking about long-term storage ?
    Post by deepee99 Thu Mar 10, 2016 3:40 pm
    Peterh,
    Guess I missed the long-term part. I was just referring to storage for the average (maybe every year) tube-roller.
    No, obviously you wouldn't want to keep your tubes near a charging battery. I don't want an active battery-charger inside the house, for that matter, tubes or no, although I guess the LiOh batts in an iPhone kick out a bit of nastiness.
    I would think that ambient moisture would be of more immediate concern. The exposed metals in a tube are susceptible to oxidation, sulfidation and God knows what else.
    I'd like, out of idle curiosity, know the physics of the threat pure hydrogen poses. A charging battery emits H2S04, correct me if I'm wrong. I'd be more worried about the sulphur.
    Post by peterh Thu Mar 10, 2016 6:20 pm
    deepee99 wrote:Peterh,
    Charging a lead-acid battery emits hydrogen and oxygen. If overcharging some h2so4 will
    be carried with the gases, this is commonly seen on top of lead-acid batteries and
    will cause harmful effects on battery poles.
    Yes moisture will affect pins and metal parts in a bad way. Corrosion under a
    plate-cap or around any connections that cross the glass might harm the glass and
    cause leakage, thus a dry environment is good. This will also save the carton boxes.
    octal tubes ( or anything that is soldered) will affect any remnants of resin, also causing corrosion.
    But again, most of these effects will be damaging in the long-term.
    Oh, i forgot, the effect of hydrogen ( and helium ) :
    it's small molecules, small enough to penetrate glass and especially the spaces
    between leads and glass. Helium is smallest, hydrogen next. Filling the tube
    with even small amounts of helium may cause flash-over since a portion of the
    space will be hydrogen ions ( atoms stripped of electrons), they will be
    attracted by the cathode and slowly hammer it's surface so to speak. In the worst
    case they will even cause flash-over, which often is deadly ( for tubes).
    Last edited by peterh on Thu Mar 10, 2016 6:25 pm; edited 1 time in total (Reason for editing : hydrogen effects)
    Post by audiobill Fri Mar 11, 2016 9:09 am
    Send them all to me for safekeeping......
    thompson12
    Post by thompson12 Sun Mar 13, 2016 2:01 pm
    Post by Roy Mottram Sun Mar 13, 2016 5:11 pm
    Mitch, nice box!
    I use an old 16x12x6" metal toolbox, very similar to this type of camera case . . .
    http://www.amazon.com/BRUBAKER-Aluminum-Digital-Camera-Padded/dp/B00JBC2BX2/ref=sr_1_34?
    for cheaper, something like this . . .
    http://www.ebay.com/itm/CRAFTSMAN-Metal-Tool-Box-Chest-w-Red-Plastic-Tray-16-W-x-7-D-x-7-5-H-/191822878436?
      Current date/time is Fri Apr 26, 2024 10:30 pm
