Hi All, new to this forum...
I have been looking to build my own phono preamp (to replace my Dynavector P75) and based on all the positive reviews I think I've settled on the PH16. I've read through the web pages, as well as the threads here, but still have a few questions I'm hoping I can get answered. I am leaning towards the exposed tube version, by the way.
1. I can't find the gain listed anywhere. I know the PH14 is listed at 44dB (for MM), but I don't see it for the PH16. Can someone confirm what it is? I will be running it
with my TS Grounded Grid preamp, which has 52dB of gain.
2. I've built several set of speakers and crossovers, but the GG preamp was my first "active" component build. It went great and works like a charm, but admittedly the
kit was very complete and had great assembly instructions so it was an easy build. Is the PH16 kit and build guide adequate for a relative beginner like me? I'm not
concerned with populating the boards ... my main concern is with making all the connections between the P/S and preamp board, transformer, etc. Any input on this
would be appreciated. I just want to make sure I'll be able to figure it all out once I get it in front of me!
3. I run a MC cartridge (currently an AT33PTG/II). Is anyone else running this cartridge, or similar, and what SUT are you using? I don't think I'll need a ton of gain, so
I'm thinking a 1:10 ratio would be adequate, and with the selectable input impedance options and a parallel resistor I should be able to get the impedance to the 100-
200 ohms the cartridge likes to see. Not so much a question, I guess, as a confirmation that I'm thinking though this correctly. I'll need to buy or build a SUT (maybe
the Luhndahl kit) since I haven't needed one with the P75, and I want to make sure I get it right before plunking any $$ down.
4. Are there other components needed in addition to what comes with the kit (wire, for example), or is it complete?
Thanks for the help ... just trying to get my mind around this before I take the leap.
Tom
Tom
