    cooler running power transformer with change in driver tubes ?
    tajanes
    tajanes
    cooler running power transformer with change in driver tubes ? Empty cooler running power transformer with change in driver tubes ?
    Post by tajanes Sun Jun 07, 2015 3:53 pm
    I early on had switched out my tube rectifier for a Weber WZ34, but most recently put in RCA 12AU7A’s (the two outside tubes on the driver board) replacing Northern Electric 12AU7’s I had for each of the 3 driver board tubes, and it seems that my power transformer (ST-120 amp) is running cooler (probably fairer to say not running quite as HOT). While I expected to mod the sound a bit, question: but these are the same family of tubes (12AU7A) I didn’t expect impact on power transformer- is there something to this ?
    cooler running power transformer with change in driver tubes ? Empty Re: cooler running power transformer with change in driver tubes ?
    Post by Maintarget Sun Jun 07, 2015 4:00 pm
    You should check your bias after changing the rectifier tube.
    tajanes
    tajanes
    Post by tajanes Sun Jun 07, 2015 4:06 pm
    sorry to confuse with the rectifier change - yes I did re bias after the change (this was mentioned as a fyi as I have read this also helps the power transformer run a bit cooler as drawing less power)
      Current date/time is Sat Apr 27, 2024 1:22 pm
