Just blew a fuse on my st-120. When I went to pull rectifier, the cap slipped right off. Not seeing anything obviously blown. Is there a way to test the WZ68 to see if it is what caused the fuse to blow?
Thanks for the help.
nathico wrote:I was out of the room when the fuse blew, but did not see any signs of distress in the outputs. Was going on almost 4 years of daily use and frequent high volume, so hopefully just the rectifier. If there is a test, would love to check it, otherwise new Weber will be here this week.
