by GP49 Sat Feb 06, 2016 12:21 am
The Mark II is essentially the same as the Mark III. It is slightly lower in power: it is a 50 watt amplifier; the Mark III is a 60 watt amplifier.
It has a simpler power supply...a 5U4 rectifier tube instead of a 5AR4, and instead of the filter choke it uses a big power resistor. It thus has a lower B+ voltage. It has EL34 output tubes instead of the 6550s in the Mark III.
The output transformer on the standard Mark II had only 8Ω and 16Ω taps but is otherwise identical. The Mark II was available with the Mark III output transformer, having 4Ω, 8Ω and 16Ω, at additional cost.
The power transformer of the Mark II is identical to that of the Mark III.
The driver circuit, which is entirely contained on one circuit board, is the identical pentode-triode circuit, using a 6AN8 tube, as the Mark III.
Servicing a Mark II is identical to servicing a Mark III. Setting the idle current (commonly called "setting bias" is done the same way; the different idle current requirement of the EL34 tube is accounted for by a cathode resistor of a different value (resistance).
Several points in such an old Mark II will likely need work: the output tubes may be tired (the 6AN8 can last forever). The quad power supply filter capacitor (the same one sold for the Mark III at Dynakit Parts is used in the Mark II). The selenium rectifier in the bias supply may have gone high-resistance; if so, the symptom being inability to bring the voltage measured during bias adjustment low enough, a modern silicon diode should be soldered across it (OBSERVE POLARITY).
The chassis of the Mark II was plated in dull silvery metal; the Mark III in chrome, which you noticed. The cover of the Mark II was black; most Mark III were brown; and the location of the fixing screws was different between the two.
GOOD LUCK!
