    Hi-Gain vs. Lo-Gain
    craigtone
    craigtone
    Hi-Gain vs. Lo-Gain Empty Hi-Gain vs. Lo-Gain
    Post by craigtone Sun Dec 21, 2008 8:21 pm
    Hey there ... I have the original tubes4hifi ST-70 driver board before there was a Hi and a Lo-Gain version. Mine is definitely hi-gain! I think my sensitivity is around 500mV! With 102dB sensitivity speakers, I'd like to convert to lo-gain. Thought it would make a good tech posting here on the forum for others in my shoes!
    TIA ...
    Hi-Gain vs. Lo-Gain Empty Hi gain vs Low gain VTA board
    Post by Bob Latino Sun Dec 21, 2008 10:21 pm
    The VTA driver board as set up with the normal components and 12AT7 medium gain tubes works well with most preamps and speaker combinations. You MAY have a little too much gain if you have very high sensitivity speakers (as you do) and/or a preamp that has high gain. You can convert a normal gain board to a low gain version if you replace the following components.
    replace R9 & 10 (which are now 2.2K 1/2 watt resistors) with 1K - 1/2 watt resistors
    replace R11 & 12 (which are now 68K 1/2 watt resistors) with 36K - 2 watt resistors
    replace R13 & 14 (which are now 150K 1/2 watt resistors) with 47K - 1/2 watt resistors
    replace R15 & 16 (which are now 7.5K 1/2 watt resistors) with 6.8K - 1/2 watt resistors
    replace R17 & 18 (which are now 12K 1/2 watt resistors) with 12K - 1 watt resistors
    replace R19-22 (which are now 51K 1/2 watt resistors) with 33K - 1 watt resistors
    replace R27 & 28 (which are now 1K 1/2 watt resistors) with 470 ohm - 1/2 watt
    Pull the three 12AT7 tubes and use either 12AU7 tubes or 12BH7 tubes in their place. Check the board layout below for the location of the components.
    Hi-Gain vs. Lo-Gain VTAdriverboardNEW_sideways
    Hi-Gain vs. Lo-Gain Empty VTA70 hi-gain VS low-gain version
    Post by Roy Mottram Sat Jan 03, 2009 7:56 pm
    yes, the sensitivity of the older version (now noted as hi-gain) using 12AT7 tubes is 0.50v input for full output, the original ST70 had a sensivity of 1.20v input for full output, so the gain is more than twice as much. Switching to 12AU7 tubes (along with the resistor changes) should cut the input sensivity by almost but not quite half, I haven't had a chance to actually measure the difference. Also, some people like the sound of 12AU7 tubes better (there are SO MANY difference brands to choose from !! )
    www.tubes4hifi.com/st70.htm
    aandre2200
    Hi-Gain vs. Lo-Gain Empty Re: Hi-Gain vs. Lo-Gain
    Post by aandre2200 Sat Feb 12, 2022 7:41 pm
    Greetings everyone.
    This is my first post on this forum. I found this topic while looking for answers.....
    I have the VTA12 driver, the low gain version with a current source and 12AU7 tubes. My problem is exactly the opposite of craigtone, the original poster of this topic; low gain preamplifier and low sensitivity speakers. I would like to increase the sensitivity of the VTA board by using 12AT7 for the first stage and changing the anode and cathode resistors (currently 30K and 1K respectively).
    Can anyone (perhaps Bob or Roy) please tell if this is doable/recommended, or is it total nonsense? Will this affect the operation of the following stages and the current source?
    Thank you for your advise and support.
    Andrei.
    Post by Roy Mottram Sun Feb 27, 2022 3:22 am
    Hi Andrea,
    reverse the directions above, also change the two 10 ohm resistors (R28 & R29) to 22 ohms for the CCS to reduce the current using 12AX7 tubes
      Current date/time is Sun Apr 28, 2024 8:39 am
