    I rebuilt my ST35
    I rebuilt my ST35 Empty I rebuilt my ST35
    Post by corndog71 Fri Jun 17, 2016 12:43 pm
    For the 3rd time I rebuilt my ST35 with a custom layout. The previous version used a large box which I needed to fit the big Clarity TC film caps for the power supply. It worked well but took up a lot of space.
    This year my older brother asked me to build him a tube amp for his office. He wanted a small footprint and every connection and control mounted on top so he can drop the amp into a fancy wood box he's going to build for it.
    I went with the Hammond 12x10x2" box and designed a new layout which incorporated Shannon Parks' driver circuit which uses a 12AX7 voltage amp and 12AU7 for phase splitter for both channels. I also used Dave Gillespie's EFB circuit for improved power and lower distortion, a single bias point for each channel, fuses on the EL84 cathodes, that stepped attenuator everyone here likes and finally 2 inputs with 1 pair of RCA and one 1/8" jack. Everything is wired point to point.
    I initially had some trouble due to a missed wire and higher voltages than expected. I think it was a bad regulator in the EFB along with feedback not being properly set. It's all good now. With inputs shorted it is dead quiet. I was surprised by how good it sounded with my cheap test speakers. Pretty cheap to put together too although there was quite a bit of labor.
    I rebuilt my ST35 AE335DDF-DBC7-42AB-8437-1559E59346D7_zpstgdtzvl9
    I rebuilt my ST35 8F1F8129-694A-4EB6-84AE-CFDF1BD84F98_zpsxmes5nne
    I rebuilt my ST35 EA183C2B-9D76-453B-94DF-2460CDC7C087_zpsaavnt60k
    I rebuilt my ST35 1733CCDE-22F6-4420-ACD3-7AEA71149845_zpsp4uuzivy
    daveshel
    daveshel
    I rebuilt my ST35 Empty Re: I rebuilt my ST35
    Post by daveshel Fri Jun 17, 2016 10:20 pm
    Nice work. Mine is still in the original chassis - stock except for the external EFB board.
    Is it a good idea to have the OPTs that close together?
    Post by corndog71 Fri Jun 17, 2016 10:30 pm
    Rogue Audio does it.
    I rebuilt my ST35 LBInterviews-RogueAudio-2
    daveshel
    daveshel
    Post by daveshel Sat Jun 18, 2016 1:49 am
    Well if Rogue Audio jumped off a bridge...
    I was thinking of the layout of the MKIII, where the PT and the OPT are adjacent, but oriented 90 degrees out of phase for polarity. And on the ST-35 and the ST-70, the OPTs were separated. So that gives rise to the question as to whether you might lose separation or gain crosstalk when they abut.
    zx
    Post by zx Sat Jun 18, 2016 11:57 am
    Nice work like always..bet sounds sweet.....hhscott...Fisher...others set there output trans like you...or you like them......thanks for the pic....
    thanks for the site Bob.........
      Current date/time is Wed May 08, 2024 11:40 am
