    Advice on Eico 666 tube tester
    Advice on Eico 666 tube tester Empty Advice on Eico 666 tube tester
    Post by Dave_in_Va Fri Jul 08, 2016 12:11 pm
    My Eico works pretty well but I'd like to get it calibrated. Any recommendations? (Preferably someone friendly who will talk on the phone.)
    Also, am I right in assuming I should use the same settings for testing a 7308 as a 6922? From my reading the 7308 is just a more robust version of the 6922.
    Thanks for your help.
    Advice on Eico 666 tube tester Empty Re: Advice on Eico 666 tube tester
    Post by Peter W. Fri Aug 12, 2016 2:54 pm
    There is much available on-line for these. Start with doing a search on Tone Lizard. There you can get a manual as well. Then fourwater dot com will give you a very comprehensive restoration and repair routine, including calibration information.
    Good testers, but LOTS of mistakes on the roll chart - again, check Tone Lizard for information on this aspect of things.
      Current date/time is Fri Apr 26, 2024 9:43 am
