    Found a use for my tape out switch
    vtshopdog
    vtshopdog
    Found a use for my tape out switch Empty Found a use for my tape out switch
    Post by vtshopdog Fri Nov 04, 2016 2:30 pm
    We listen to radio 2 or 3 hours most mornings and there is no need to have consumable tube gear running 15-20 hours a week for this.  I did a rebuild on my SP-12 last spring and rewired the tape out switch as an A/B splitter output downstream of my selector switch to allow access to all sources without firing up the tube gear.
    So it pretty much goes like so:
    All component RCA inputs connected to SP-12 selector switch
    SP-12 selector to Tape switch
    Tape switch "source" position goes on to volume controls, SP-12 board and on to M125's and main system - stock configuration.
    Tape switch "tape out" position goes to back panel "Tape Out" RCA's and on to a small passive preamp (built from Tube Cad A3 stepped attenuator PCB kit) and on to another small power amp and separate small affordable speakers.
    What this allows is I can now listen to all sources without firing up the tube pre (save phono).  Since the passive pre attenuators end up grounding into the SP-12 I was worried about creating ground loops in this mess of possible switch modes, but no issue and probably more dumb luck than any sort of savvy - (I'll take it when it comes my way)
    Added a couple photos in an edit today.
    Found a use for my tape out switch PASS%20PRE.JPG_zpsa5h0q7a2
    Found a use for my tape out switch PRE%20INSIDE.JPG_zpslr8qh1bn
    Found a use for my tape out switch Empty Re: Found a use for my tape out switch
    Post by Roy Mottram Tue Nov 08, 2016 3:55 pm
    VT,
    very smart use of the tape monitor switch!!
    this is almost identical info I give to people who want a "Home Theater Bypass" switch to their expensive/fancy home theater 7.2 receiver.
    vtshopdog
    vtshopdog
    Post by vtshopdog Tue Nov 15, 2016 8:52 pm
    Ha - I'm not surprised, but "small affordable speakers" placed on the floor tucked against wall in a very sub-optimal location sound, well, pretty bad, even just for listening to NPR in the morning.
    No "sweet spot" in this setup ...
      Current date/time is Fri Apr 26, 2024 11:44 pm
