If you had two of them and wanted to use one for each channel, how would you hook them up?
(Sorry, too late for me to figure this out for myself.)
Thanks in advance.
Thanks in advance.
Parallelling is really no option as the tubes are probably not that equal. It mightDave_in_Va wrote:If you had two of them and wanted to use one for each channel, how would you hook them up?
Thanks in advance.
Thanks in advance.
Each individual amp will get 2 output's that might be slightly different. To drivePeter W. wrote:Dave_in_Va wrote:If you had two of them and wanted to use one for each channel, how would you hook them up?
Thanks in advance.
Do they not have a mono-stereo switch? If so, that is your answer.
Each individual amp becomes, effectively a 4-output-tube mono amp.
Thanks in advance.
