    How i add ventilation slots to my Dynaco PAS 3 with basic tools.
    starwatcher
    How i add ventilation slots to my Dynaco PAS 3 with basic tools. Empty How i add ventilation slots to my Dynaco PAS 3 with basic tools.
    Post by starwatcher Fri Mar 30, 2018 11:07 pm
    When i saw the PAS cover with ventilation slots at Dynakit i said to myself; i can do that.
    I use the screws holes as reference and do the layout pictured below.
    I drill 8 holes with a 3/32 drill bit.
    I enlarge the holes with a 3/16 drill bit. (cutting oil or any oil will help)
    I use a 1/8 drill to rough out the slots and use swiss files first and a larger file to complete the slots.
    Brown paint will complete the job.
    I have many years of experience at an airplane factory so don't be angry at me if you messed up your cover.
    How i add ventilation slots to my Dynaco PAS 3 with basic tools. 41083225402_25377ca9ff_cP1010116 by André Fiset, sur FlickrHow i add ventilation slots to my Dynaco PAS 3 with basic tools. 39317695940_4b0fec4a7c_cP1010113 by André Fiset, sur FlickrHow i add ventilation slots to my Dynaco PAS 3 with basic tools. 41083248122_6d9ddcd978_cP1010114 by André Fiset, sur FlickrHow i add ventilation slots to my Dynaco PAS 3 with basic tools. 27253496308_ffe017de03_cP1010118 by André Fiset, sur FlickrHow i add ventilation slots to my Dynaco PAS 3 with basic tools. 40415470244_cca118e79d_cP1010120 by André Fiset, sur FlickrHow i add ventilation slots to my Dynaco PAS 3 with basic tools. 40415474674_74ee9cc918_cP1010119 by André Fiset, sur Flickr
    Dogstar
    How i add ventilation slots to my Dynaco PAS 3 with basic tools. Empty Re: How i add ventilation slots to my Dynaco PAS 3 with basic tools.
    Post by Dogstar Sat Mar 31, 2018 5:48 am
    Looks like you did a pretty good job using all hand tools for the layout work and fabrication.
    Post by Dave_in_Va Sat Mar 31, 2018 9:48 am
    Clean work. Great job.
    I'd screw something like that up in about 5 seconds :-(
    cci1492
    cci1492
    Post by cci1492 Sat Mar 31, 2018 10:26 am
    Man that looks professional. A lot harder to actually do and make it look like that than most actually think.
    starwatcher
    Post by starwatcher Mon Apr 02, 2018 11:12 pm
    Thanks for your good words.
    I check with my laser thermometer and i found if i add slots on the bottom plate near the faceplate it will help for cooling the cover for an other 5 degrees for a total of 10 degrees celsius over the ambient surfaces.
    It was not particularly difficult for me but it need a little patience for best results.
    If you use an abrasive wheel go slowly of the heat will damage the paint.
    I wanted to show it can be done at home.
    Regards.
    How i add ventilation slots to my Dynaco PAS 3 with basic tools. 40303540585_3c9576bef3_cP1010121 by Bill Wong, sur Flickr
    kve777
    Post by kve777 Mon Apr 23, 2018 10:26 am
    Nice work!
    I cut down an FM-3 mesh cover to fit on one of my PAS' for better ventilation.
      Current date/time is Fri Apr 26, 2024 8:24 pm
