    Mk 4 loud hum and where I found the problem..
    Pooch
    Mk 4 loud hum and where I found the problem.. Empty Mk 4 loud hum and where I found the problem..
    Post by Pooch Mon Mar 21, 2011 5:11 pm
    This is just a FYI for someone who may come across this same thing. I had a loose RCA input that wasn't making ground (I use the nylon spacers on the new gold RCA). At any rate I guess the grounding ring wasn't making contact with the ouside of the RCA. Results in one hell of a noise out of the speaker!! affraid I dont know if these nylon spacers are worth it or not? Maybe I'll just eliminate them. The idea I had was to try and keep a common ground point, ie star grounding through the VTA board. Not sure if its worth it, though.
    Another thing that could cause a poor grnd is the spacer screws on the VTA board. I found that not only tightening the hex nuts in the bottom is necessary, so are the screws on the top of the board. Seems that when I backed the nuts off on the bottom the screws on the top also spun loose. I thought this was my hum problem, but no cigar. It was the RCA input.
    One more thing, I disconnected the AC ground and it quieted the residual noise to virtualy nothing. I have an IEC input and I think I'll swap it for a 2 wire IEC, 17 or 18 is the number IIRC. That way the next owner won't be thinking it's grounded (and I get to use a thinner cord). cheers
    Mk 4 loud hum and where I found the problem.. Empty I am having a similar problem with MK 4
    Post by Guest Wed Jun 29, 2011 7:03 pm
    I just finish rebuilding a pair of MK4's, and have a noticeable 60 cycle hum. I owned a Quicksilver GLA amp, and Mike Sanders said he lifted the ground on the amp for the same reasons you describe. One of the MK 4's is producing a loud popping and cracking noise. According to Bob Latino's trouble shooting guide, it is most likely high voltage jumping to chassis ground, ou have any experience with this? Thanks!
      Current date/time is Fri Apr 26, 2024 8:38 am
